[GRASS-dev] r.info in grass 7 misses the "-m" flag
Markus Neteler neteler at osgeo.org
Sat Aug 3 15:06:59 PDT 2013
On Sat, Aug 3, 2013 at 2:50 AM, Hamish <hamish_b at yahoo.com> wrote:
> probably the "none" values for 'r.info -e' should just be empty,
> to make them easier to parse & work with `eval` directly.
Yes, this would be good.
I imported "black marble" with r.in.gdal, then r.composite and get
GRASS 7.0.svn (europe_laea):~ > r.info -e blackmarble2012_italy.rgb
title= (blackmarble2012_italy.rgb)
units="none"
vertical_datum="none"
timestamp="none"
which isn't quite `eval` parseable...
Markus
