[GRASS-dev] [GRASS GIS] #2042: wxgui: no more menu access to r.in.gdal / v.in.ogr
trac at osgeo.org
Sun Aug 4 19:35:43 PDT 2013
Reporter: mlennert | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: wxGUI | Version: svn-trunk
Keywords: r.in.gdal, v.in.ogr, gui | Platform: Unspecified
Cpu: Unspecified |
Comment(by cmbarton):
I just had a chance to catch up on this discussion. I did not realize that
the button to r.in.gdal had disappeared.The import wrapper is nice, but it
is missing important r.in.gdal functionality and for this reason is not a
full substitute for the original grass module. In addition to lacking
control over input of multiband data, it also lacks the ability to create
a new location from a georeferenced file, or read a GCP file for
reproduction. You also do not have access to the r.in.gdal help from
within the wrapper. There are similar issues with v.in.ogr.
Do I understand from the discussion that r.in.gdal has now been added to
the list of modules that need the semi-secret --ui flag? I hope not,
especially if it can no longer be launched from within the wrapper.
Overall, I think the need to specify the --ui to launch some modules but
not others is really confusing to users trying to use the command line
more.
Michael
Ticket URL: <https://trac.osgeo.org/grass/ticket/2042#comment:15>
