[GRASS-dev] [GRASS GIS] #2054: d.barscale module gui doesn't start from the command line
GRASS GIS trac at osgeo.org
Mon Aug 5 00:01:38 PDT 2013
  Reporter:  hamish    |       Owner:  grass-dev@…
      Type:  defect    |      Status:  closed
  Priority:  critical  |   Milestone:  6.4.4
 Component:  wxGUI     |     Version:  svn-develbranch6
Resolution:  fixed     |    Keywords:  d.barscale
  Platform:  Linux     |         Cpu:  x86-64
Comment(by annakrat):
 Replying to [comment:3 hamish]:
 > 'd.erase --ui' was the only other display module I found with the
 trouble. What was the connection with the color picker? Can we expect any
 others?
 It has nothing to do with display commands. There was some trick to set
 focus on the first option which needed widget id which happened to be None
 for some reason. Forms are full of these small tricks and it's almost
 impossible to test it completely because each module is a special
 combination.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2054#comment:4>
