[GRASS-dev] Regarding "d.frame"-like functionality in grass 7
    Nikos Alexandris
    nik at nikosalexandris.net
    Tue Aug  6 06:32:06 PDT 2013
Hi list,
I have found only two threads related to "d.frame" and grass 7 (in which
version of course d.frame does not exist).
(2008) http://lists.osgeo.org/pipermail/grass-dev/2008-October/040353.html
(2010) http://lists.osgeo.org/pipermail/grass-user/2010-September/057769.html
Alsom, in <file:///osgeo/src/grass7_trunk/dist.x86_64-unknown-linux-
gnu/docs/html/variables.html> there is:
GRASS_FRAME
contains 4 coordinates, top,bottom,left,right, defining the initial frame.
Is there elsewhere a "d.frame" like functionality, for inside grass7,
documented?
Thank you, Nikos
