[GRASS-dev] g.remove rast prefered
Martin Landa landa.martin at gmail.com
Sun Aug 11 02:05:44 PDT 2013
Hi all,
AFAR there was already discussion related to g.remove/g.copy/g.rename
modules. Before we start releasing GRASS7 tech-preview I would prefer
to change the current behaviour.
g.remove x
Removing raster <x>
WARNING: Raster map <x> not found
WARNING: <x> nothing removed
to
g.remove x
ERROR: Invalid data element (valid options: rast,vect..)
g.remove rast=x
What do you think? Martin
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
