[GRASS-dev] Why the parameters of "g.region" are defined as string?
Benjamin Ducke benducke at fastmail.fm
Mon Aug 12 08:54:09 PDT 2013
On 08/12/2013 05:39 PM, Pietro wrote:
> Hi all,
> Today I've just realize that the parameter of g.region are defined as string:
> http://trac.osgeo.org/grass/browser/grass/trunk/general/g.region/main.c#L203
[snip]
> Why should we not use TYPE_DOUBLE for these parameters (n,s,e,w,)? Is
> it to not loose significant digits?
It needs to be a string, so that you can use
common lat/lon notations in the format "°dd'mm''ss".
Ben
> Sorry if this has already been discussed, but I was not able to find
> any reference in the mailing-list's archive.
> Best regards
> Pietro
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
Dr. Benjamin Ducke, M.A.
{*} Geospatial Consultant
{*} GIS Developer
