[GRASS-dev] v.in.ascii Column numbers must not be negative
Vaclav Petras
wenzeslaus at gmail.com
Thu Aug 15 06:56:47 PDT 2013
On 15 August 2013 02:07, Yann Chemin <ychemin at gmail.com> wrote:
> > ERROR: Column numbers must not be negative
The error messages is probably wrong, columns are indexed from 1.
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20130815/9417e0db/attachment.html>
