[GRASS-dev] [GRASS GIS] #1941: wxGUI fails with Japanese locale
trac at osgeo.org
Thu Aug 22 07:27:31 PDT 2013
Reporter: venkat | Owner: grass-dev@…
Type: defect | Status: new
Priority: blocker | Milestone: 7.0.0
Component: wxGUI | Version: svn-trunk
Keywords: wingrass | Platform: MSWindows 7
Cpu: x86-32 |
Comment(by mlennert):
Replying to [comment:6 improgrammer]:
> I encounter similar problem.
> I suggest modifying the sementics of gtask.get_interface_description()
to return xml in "utf-8" encoding. see attachment
"patch_for_ticket_1941.patch".
> Rational:
> 1. The following code segment in task.py and forms.py is too limited
because ("cp936","cp932", etc) need similar converting:
> enc = locale.getdefaultlocale()[1]
> if enc and enc.lower() == "cp932":
> p = re.compile('encoding="' + enc + '"', re.IGNORECASE)
> tree = etree.fromstring(p.sub('encoding="utf-8"',
get_interface_description(name).decode(enc).encode("utf-8")))
> else:
> tree = etree.fromstring(get_interface_description(name))
> 1. Any where the gtask.get_interface_description() is called, the
"convert-to-utf8" is needed;
> 1. Properly constructed interface description text is xml text with
proper <?xml ... encoding="some-text-encoding"?> statement, extract text
encoding schema from these xml text is more rational than extract enc from
locale package.
Can someone else working in a Japanese Windows environment test this patch
Ticket URL: <https://trac.osgeo.org/grass/ticket/1941#comment:7>
