[GRASS-dev] [GRASS GIS] #2060: Unable to make a deepcopy of a pygrass Module object
GRASS GIS trac at osgeo.org
Mon Aug 26 04:55:44 PDT 2013
 Reporter:  huhabla                    |       Owner:  grass-dev@…
     Type:  defect                     |      Status:  new
 Priority:  normal                     |   Milestone:  7.0.0
Component:  Python                     |     Version:  unspecified
 Keywords:  pygrass, Module, deepcopy  |    Platform:  All
      Cpu:  All                        |
 I am trying to make copies of a single pygrass.modules.Module() object
 using copy.deepcopy:
 >>> import grass.pygrass as pg
 >>> m = pg.modules.Module("g.region", flags="p", run_=False)
 >>> m.run()
 projection: 99 (Lambert Conformal Conic)
 zone:       0
 datum:      nad83
 ellipsoid:  a=6378137 es=0.006694380022900787
 north:      80
 south:      0
 west:       0
 east:       120
 nsres:      10
 ewres:      10
 rows:       8
 cols:       12
 cells:      96
 >>> import copy
 >>> n = copy.deepcopy(m)
 >>> n.run()
   File "<stdin>", line 1, in <module>
   File "/home/soeren/src/grass7.0/grass_trunk/dist.x86_64-unknown-linux-
 gnu/etc/python/grass/pygrass/modules/interface/module.py", line 282, in
 run
     if self.inputs['stdin'].value:
 KeyError: 'stdin'
 But it fails with a key error. Looks like (thanks for Pietro's
 investigation) that the _getattr_ function in
 grass.pygrass.modules.interface.typedict may be the problem.[1]
 [1] http://www.peterbe.com/plog/must__deepcopy__
Ticket URL: <http://trac.osgeo.org/grass/ticket/2060>
