[GRASS-dev] KeyError with python grass.raster_info() in GRASS 7
Johannes Radinger
johannesradinger at gmail.com
Wed Aug 28 03:30:02 PDT 2013
when I try to get the max value of a raster map via python and
grass.raster_info() in GRASS70 (revision 57523), I get following error:
grass.raster_info("test3")['max']
D1/1: grass.script.core.start_command(): r.info -gre map=test3
File "<input>", line 1, in <module>
File "/usr/local/grass-7.0.svn/etc/python/grass/script/raster.py", line
80, in raster_info
kv[k] = float_or_null(kv[k])
KeyError: 'min'
Is that easy to fix?
/Johannes
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20130828/19c48d6e/attachment.html>
