[GRASS-dev] [GRASS GIS] #1778: Typing in g.region without parameters does not open a g.region window
trac at osgeo.org
Thu Aug 29 09:40:40 PDT 2013
Reporter: pvanbosgeo | Owner: grass-dev@…
Type: defect | Status: new
Priority: critical | Milestone: 7.0.0
Component: Default | Version: svn-trunk
Keywords: g.region, r.colors, r.mask | Platform: Linux
Cpu: x86-64 |
Comment(by cmbarton):
Or something...
The problem you describe is indeed annoying. But it does not seem like a
good idea to have modules behave inconsistently and unpredictably from the
user perspective in order to solve it. The --ui flag should be default
behavior and not need the flag. Consistent behavior was one of the goals
of getting rid of persistent processes in modules.
The actual problem, and to my mind implementing a solution, seems to lie
in the modules that should run without a dialog rather than altering the
default behavior of launching a dialog when a module is run without
parameters. A logically better fix is to require the --ui flag only on
modules whose normal behavior is to run without arguments. g.region is not
such a module; d.erase is such a module. Perhaps there are even more
elegant fixes.
Michael
Ticket URL: <http://trac.osgeo.org/grass/ticket/1778#comment:15>
