[GRASS-dev] Fwd: [Bug 1037102] New: grass FTBFS if "-Werror=format-security" flag is used
Markus Neteler
neteler at osgeo.org
Tue Dec 3 04:11:26 PST 2013
with the security flag ("-Werror=format-security") enabled, GRASS
fails to build.
How to deal with this kind of error? I could then apply it elsewhere:
cd lib/gis/
make
null_val.c: In function ‘InitError’:
null_val.c:115:5: error: format not a string literal and no format
arguments [-Werror=format-security]
G_fatal_error(errMsg);
cd vector/v.vol.rst
main.c: In function ‘main’:
main.c:587:2: error: format not a string literal and no format
G_debug(1, db_get_string(&sql));
cc1: some warnings being treated as errors
and so on.
thanks
Markus
---------- Forwarded message ----------
Date: Tue, Dec 3, 2013 at 4:08 AM
Subject: [Bug 1037102] New: grass FTBFS if "-Werror=format-security"
flag is used
https://bugzilla.redhat.com/show_bug.cgi?id=1037102
Bug ID: 1037102
Summary: grass FTBFS if "-Werror=format-security" flag is used
Product: Fedora
Version: rawhide
Component: grass
Description of problem
grass fails to build if "-Werror=format-security" flag is used.
a2b.c:103:3: error: format not a string literal and no format arguments
a2b.c:136:3: error: format not a string literal and no format arguments
a2b.c:154:3: error: format not a string literal and no format arguments
a2b.c:172:6: error: format not a string literal and no format arguments
We are working on a proposal to enable "-Werror=format-security" for all
packages. Once this flag is enabled, GCC will refuse to compile code that could
be vulnerable to a string format security flaw. For more details, please see
https://fedorahosted.org/fesco/ticket/1185 page.
To understand why it is important to fix this, please see
https://fedoraproject.org/wiki/Format-Security-FAQ page.
How to fix this
The fix for these errors is quite simple. It's a matter of changing a
line like,
printf(foo);
to read,
printf("%s", foo);
That's it.
Please fix this issue in rawhide with a patch (which you should submit
to upstream to merge moving forward). Please do a new build with the
fix in rawhide. Other releases do not need to be directly fixed, but
there should be no harm in pushing out this fix/patch with other needed
changes to those branches.
In the event you don't fix this bug before the next mass rebuild,
provenpackagers may step in and update your package(s) to fix this
issue.
How reproducible
Build grass-6.4.3-5.fc21.src.rpm with "-Werror=format-security" flag to
reproduce the problem.
To make this process easier, you can use a modified "redhat-rpm-config" package
from http://people.fedoraproject.org/~halfie/artifacts/redhat-rpm-config/ URL.
$ sha256sum redhat-rpm-config-9.1.0-56.fc20.*
faad7594b2080fe76497d0ce50808c905a93dd7b41c1defdde5ca57e3833d3d2
redhat-rpm-config-9.1.0-56.fc20.noarch.rpm
5aa9357174305c7285ffdbc92d7ffe1c07a8a95d5459b930461308f5aad75413
redhat-rpm-config-9.1.0-56.fc20.src.rpm
