[GRASS-dev] trying to compile GRASS 7 on Mavericks
Michael Barton Michael.Barton at asu.edu
Tue Dec 3 16:12:33 PST 2013
I got it to compile fine using GDAL 1.10. But the GUI still crashes on startup due to problems in the xml toolbox.
Michael
______________________________
C. Michael Barton
Director, Center for Social Dynamics & Complexity
Professor of Anthropology, School of Human Evolution & Social Change
Arizona State University
Tempe, AZ  85287-2402
USA
voice:  480-965-6262 (SHESC), 480-965-8130/727-9746 (CSDC)
fax:          480-965-7671(SHESC), 480-727-0709 (CSDC)
www:  http://csdc.asu.edu, http://shesc.asu.edu
http://www.public.asu.edu/~cmbarton
On Dec 3, 2013, at 12:43 PM, Anna Petrášová <kratochanna at gmail.com<mailto:kratochanna at gmail.com>> wrote:
Hi all,
I am still having problems to compile GRASS on Maverick, it cannot find GDAL, I already reinstalled the frameworks and Xcode, too. I tried to compile the simple code which seems to be compiled during configure:
#include <gdal.h>
int main(int argc, const char* argv[])
    GDALOpen("foo", GA_ReadOnly);
which gives me:
gis-imac:Desktop akratoc$ gcc test.c
test.c:14:5: warning: ignoring return value of function declared with warn_unused_result attribute [-Wunused-result]
1 warning generated.
Undefined symbols for architecture x86_64:
  "_GDALOpen", referenced from:
      _main in test-sew0gz.o
ld: symbol(s) not found for architecture x86_64
clang: error: linker command failed with exit code 1 (use -v to see invocation)
I am having the same problem also on another computer. Any help appreciated.
Thanks,
Anna
On Fri, Nov 29, 2013 at 3:27 PM, Markus Neteler <neteler at osgeo.org<mailto:neteler at osgeo.org>> wrote:
On Fri, Nov 29, 2013 at 9:02 PM, Michael Barton <Michael.Barton at asu.edu<mailto:Michael.Barton at asu.edu>> wrote:
> I've been chilling out after Thanksgiving and thought I'd try compiling
> GRASS on Mavericks.
> I had a couple of configure issues.
> --with-odbc failed. Is this not included with Mavericks or do I need to
> reference it in some other way?
> --with nls also failed. I wonder if I have to update the version of gettext
> that I compiled on Lion?
> When I dropped these out, I got it to compile. But it errors out with the
> following:
>   "___sincos_stret", referenced from:
I found these "random" links:
http://trac.macports.org/ticket/40961
http://stackoverflow.com/questions/19015780/sincos-stret-undefined-symbol-when-linking
Perhaps giving the right idea..
Markus
grass-dev mailing list
grass-dev at lists.osgeo.org<mailto:grass-dev at lists.osgeo.org>
http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20131204/1409ebc7/attachment.html>
