[GRASS-dev] i.segment: Invalid region id -1
Nikos Alexandris
nik at nikosalexandris.net
Wed Dec 4 01:04:21 PST 2013
On Wednesday 04 of December 2013 10:56:48 Nikos Alexandris wrote:
> What do you think, a short warning in the manual that "the resolution of the
> computational region should be identical between subsequent segmentations
> that make use of a seed map"?
Or, maybe more "aggressively", a check if the resolution of the seed map is
identical to the region's resolution at the time of the segmentation process?
N
