[GRASS-dev] tgrass compilation issue
Sören Gebbert
soerengebbert at googlemail.com
Wed Dec 4 03:20:49 PST 2013
Hi Martin,
this issue is hopefully fixed in r58383.
Best regards
Soeren
2013/12/4 Martin Landa <landa.martin at gmail.com>:
> Hi,
> since today I have problem with compilation of temporal modules, see bellow.
> if [ "/opt/src/grass_trunk/dist.x86_64-unknown-linux-gnu/scripts/t.create"
> != "" ] ; then GISRC=/opt/src/grass_trunk/dist.x86_64-unknown-linux-gnu/demolocation/.grassrc70
> GISBASE=/opt/src/grass_trunk/dist.x86_64-unknown-linux-gnu
> PATH="/opt/src/grass_trunk/dist.x86_64-unknown-linux-gnu/bin:/opt/src/grass_trunk/dist.x86_64-unknown-linux-gnu/bin:/opt/src/grass_trunk/dist.x86_64-unknown-linux-gnu/scripts:$PATH"
> PYTHONPATH="/opt/src/grass_trunk/dist.x86_64-unknown-linux-gnu/etc/python:/opt/src/grass_trunk/dist.x86_64-unknown-linux-gnu/etc/python:$PYTHONPATH"
> LD_LIBRARY_PATH="/opt/src/grass_trunk/dist.x86_64-unknown-linux-gnu/bin:/opt/src/grass_trunk/dist.x86_64-unknown-linux-gnu/lib:/opt/src/grass_trunk/dist.x86_64-unknown-linux-gnu/lib:"
> LC_ALL=C /opt/src/grass_trunk/dist.x86_64-unknown-linux-gnu/scripts/t.create
> --html-description < /dev/null | grep -v '</body>\|</html>' >
> t.create.tmp.html ; fi
> Traceback (most recent call last):
> File "/opt/src/grass_trunk/dist.x86_64-unknown-linux-gnu/scripts/t.create",
> line 60, in <module>
> import grass.temporal as tgis
> File "/opt/src/grass_trunk/dist.x86_64-unknown-linux-gnu/etc/python/grass/temporal/__init__.py",
> line 25, in <module>
> from mapcalc import *
> File "/opt/src/grass_trunk/dist.x86_64-unknown-linux-gnu/etc/python/grass/temporal/mapcalc.py",
> line 16, in <module>
> from open import *
> ImportError: No module named open
> make: *** [t.create.tmp.html] Error 1
> rm t.create.tmp.html
> Martin
> Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
