[GRASS-dev] trying to compile GRASS 7 on Mavericks
Anna Petrášová kratochanna at gmail.com
Wed Dec 4 15:25:00 PST 2013
Hi Michael,
thank you for the instructions, I will try it tomorrow or so.
Anna
On Wed, Dec 4, 2013 at 5:50 PM, Michael Barton <Michael.Barton at asu.edu>wrote:
> I was able to compile and open GRASS 7 under Mavericks. Here is what I’ve
> done so far.
> 1. I had to uninstall and reinstall Xcode and the CommandLineTools. You
> may or may not have to do this. If you have not yet updated Xcode, you
> should delete your existing Xcode before doing so. There are several
> approaches to doing this depending on how you installed it. There are
> references to using an Uninstall_Devtools utility that supposedly lives in
> /Library/Developer. I’ve never had this. If you installed from the app
> store, you need to open the launch pad and delete Xcode from there. AFAIK,
> there is no way to delete the CommandLineTools (unless you want to do it
> one by one). I also installed the AuxTools because I had these before. I
> don’t know that I need them though.
> 2. I also installed wxPython 2.9.5 so I can compile in 64bit Python 2.7. I
> also installed all the current frameworks from William’s site (I only had
> to update to GDAL 1.10)
> 3. I had to drop out of my configuration script reference to gettext and
> odbc. I supposed I need to recompile gettext under Mavericks (and maybe LAS
> but I don’t yet know). But I don’t know where the ODBC issue is coming
> from. I didn’t explicitly install that previously.
> 4. I opened a terminal window, cd to the proper source directory and then
> typed…
> export CXX=g++
> 5. I configured with…
> ./configure --with-freetype
> --with-freetype-includes="/Library/Frameworks/FreeType.framework/unix/include/freetype2
> /Library/Frameworks/FreeType.framework/unix/include"
> --with-freetype-libs=/Library/Frameworks/FreeType.framework/unix/lib
> --with-gdal=/Library/Frameworks/GDAL.framework/Programs/gdal-config
> --with-proj
> --with-proj-includes=/Library/Frameworks/PROJ.framework/unix/include
> --with-proj-libs=/Library/Frameworks/PROJ.framework/unix/lib
> --with-proj-share=/Library/Frameworks/PROJ.framework/Resources/proj
> --with-geos=/Library/Frameworks/GEOS.framework/Versions/3/unix/bin/geos-config
> --with-jpeg-includes=/Library/Frameworks/UnixImageIO.framework/unix/include
> --with-jpeg-libs=/Library/Frameworks/UnixImageIO.framework/unix/lib
> --with-png-includes=/Library/Frameworks/UnixImageIO.framework/unix/include
> --with-png-libs=/Library/Frameworks/UnixImageIO.framework/unix/lib
> --with-tiff-includes=/Library/Frameworks/UnixImageIO.framework/unix/include
> --with-tiff-libs=/Library/Frameworks/UnixImageIO.framework/unix/lib
> --with-cairo
> --with-cairo-includes="/Library/Frameworks/cairo.framework/unix/include/cairo
> /Library/Frameworks/cairo.framework/unix/include"
> --with-cairo-libs=/Library/Frameworks/cairo.framework/unix/lib
> --with-cairo-ldflags="-lcairo" --without-postgres --without-mysql
> --with-sqlite
> --with-sqlite-libs=/Library/Frameworks/SQLite3.framework/unix/lib
> --with-sqlite-includes=/Library/Frameworks/SQLite3.framework/unix/include
> --with-fftw-includes=/Library/Frameworks/FFTW3.framework/unix/include
> --with-fftw-libs=/Library/Frameworks/FFTW3.framework/unix/lib --with-x
> --with-cxx --with-opengl=aqua --without-readline
> --prefix=/Applications/GRASS --enable-macosx-app --with-python
> --with-wxwidgets=/usr/local/lib/wxPython-2.9.5.0/bin/wx-config
> --with-tcltk-includes="/Library/Frameworks/Tcl.framework/Headers
> /Library/Frameworks/Tk.framework/Headers
> /Library/Frameworks/Tk.framework/PrivateHeaders"
> --with-tcltk-libs="/usr/local/tcltk_active/lib" --with-macosx-archs="i386
> x86_64" --with-liblas="/usr/local/bin/liblas-config" --with-opencl
> 6. I ran…
> make GDAL_DYNAMIC=
> 7. I ran…
> make bindist
> Making a binary distribution package partly failed. I got a GRASS app but
> not a package, because the packagemaker is no longer with the AuxTools.
> I’ll need guidance from William as to how to use whatever new package
> making tools are in the Dev Tools.
> So far, I have not compiled for 10.7 compatibility or bundled wxPython
> (I’m doing that now)
> wxPython still crashes on startup due to its inability to create
> menutree.xml and module_tree_menudata.xml. I have to do a work around. I
> was hoping that this might clear up with Python 2.7 and wxPython 2.9. But
> it has not. So this is a problem in the code and not in trying to maintain
> backward compatibility.
> Once I did all this, GRASS 7 launches. It looks different with wxPython
> 2.9—more Linux like and less Maclike to my eyes.
> Also, the terminal begins kicking out the following message every second
> or so:
> 2013-12-04 15:31:50.761 Python[78631:d0b] CoreText performance note:
> Client called CTFontCreateWithName() using name ".Lucida Grande UI" and got
> font with PostScript name ".LucidaGrandeUI". For best performance, only use
> PostScript names when calling this AP
> This needs to be fixed.
> I’ll keep you all informed about compiling for Lion and packaging wxPython.
> Michael
> ______________________________
> C. Michael Barton
> Director, Center for Social Dynamics & Complexity
> Professor of Anthropology, School of Human Evolution & Social Change
> Arizona State University
> Tempe, AZ  85287-2402
> USA
> voice:  480-965-6262 (SHESC), 480-965-8130/727-9746 (CSDC)
> fax:          480-965-7671(SHESC), 480-727-0709 (CSDC)
> www:    http://csdc.asu.edu, http://shesc.asu.edu
>                 http://www.public.asu.edu/~cmbarton
> On Dec 3, 2013, at 5:53 PM, Helena Mitasova <hmitaso at ncsu.edu> wrote:
> > Michael,
> > can you please share your configure file that you are using?
> > thanks, Helena
> > Helena Mitasova
> > Associate Professor
> > Department of Marine, Earth, and Atmospheric Sciences
> > 2800 Faucette Drive, Rm. 1125 Jordan Hall
> > North Carolina State University
> > Raleigh, NC 27695-8208
> > hmitaso at ncsu.edu
> > "All electronic mail messages in connection with State business which
> are sent to or received by this account are subject to the NC Public
> Records Law and may be disclosed to third parties.”
> > On Dec 3, 2013, at 7:12 PM, Michael Barton wrote:
> >> I got it to compile fine using GDAL 1.10. But the GUI still crashes on
> startup due to problems in the xml toolbox.
> >> Michael
> >> C. Michael Barton
> >> USA
> >> voice:
> >> www:
> >> On Dec 3, 2013, at 12:43 PM, Anna Petrášová <kratochanna at gmail.com>
> wrote:
> >>> Hi all,
> >>> I am still having problems to compile GRASS on Maverick, it cannot
> find GDAL, I already reinstalled the frameworks and Xcode, too. I tried to
> compile the simple code which seems to be compiled during configure:
> >>> #include <gdal.h>
> >>> int main(int argc, const char* argv[])
> >>>    GDALOpen("foo", GA_ReadOnly);
> >>> which gives me:
> >>> gis-imac:Desktop akratoc$ gcc test.c
> >>> test.c:14:5: warning: ignoring return value of function declared with
> warn_unused_result attribute [-Wunused-result]
> >>> 1 warning generated.
> >>> Undefined symbols for architecture x86_64:
> >>>  "_GDALOpen", referenced from:
> >>>      _main in test-sew0gz.o
> >>> ld: symbol(s) not found for architecture x86_64
> >>> clang: error: linker command failed with exit code 1 (use -v to see
> invocation)
> >>> I am having the same problem also on another computer. Any help
> appreciated.
> >>> Thanks,
> >>> Anna
> >>> On Fri, Nov 29, 2013 at 3:27 PM, Markus Neteler <neteler at osgeo.org>
> wrote:
> >>> On Fri, Nov 29, 2013 at 9:02 PM, Michael Barton <
> Michael.Barton at asu.edu> wrote:
> >>>> I've been chilling out after Thanksgiving and thought I'd try
> compiling
> >>>> GRASS on Mavericks.
> >>>> I had a couple of configure issues.
> >>>> --with-odbc failed. Is this not included with Mavericks or do I need
> to
> >>>> reference it in some other way?
> >>>> --with nls also failed. I wonder if I have to update the version of
> gettext
> >>>> that I compiled on Lion?
> >>>> When I dropped these out, I got it to compile. But it errors out with
> the
> >>>> following:
> >>>>  "___sincos_stret", referenced from:
> >>> I found these "random" links:
> >>> http://trac.macports.org/ticket/40961
> http://stackoverflow.com/questions/19015780/sincos-stret-undefined-symbol-when-linking
> >>> Perhaps giving the right idea..
> >>> Markus
> >>> _______________________________________________
> >>> grass-dev mailing list
> >>> grass-dev at lists.osgeo.org
> >>> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20131204/606ed7de/attachment-0001.html>
