[GRASS-dev] segfault on 'r.stream.extract' - debian armh
epi massimodisasha at gmail.com
Fri Dec 6 15:33:47 PST 2013
i tried to rebuild grass with
CFLAGS='-g -Wal’
CXXFLAGS='-g -Wal’
this the full log :
https://gist.github.com/epifanio/7833957
On Dec 6, 2013, at 5:18 PM, epi <massimodisasha at gmail.com> wrote:
> googling …
> is it possible that in :
> http://svn.osgeo.org/grass/grass/trunk/raster/r.stream.extract/
> there may be some assembly code that gets executed which won't work under armhf  ?
> Massimo.
> On Dec 6, 2013, at 4:37 PM, epi <massimodisasha at gmail.com> wrote:
>> i tried to add :
>> handle SIGILL nostop
>> to have more debug ..
>> i can’t understand the log :/
>> (gdb) handle SIGILL nostop
>> Signal        Stop	Print	Pass to program	Description
>> SIGILL        No	Yes	Yes		Illegal instruction
>> (gdb)
>> (gdb) exec-file r.stream.extract elevation=elevation at PERMANENT accumulation=accum threshold=20 stream_rast=stream_network stream_vect=streams --o
>> (gdb) r
>> Starting program: /home/epi/Envs/env1/grass-7.0.svn/bin/r.stream.extract .stream.extract elevation=elevation50m at PERMANENT accumulation=accum threshold=40 stream_rast=stream_network stream_vect=streams --o
>> [Thread debugging using libthread_db enabled]
>> Using host libthread_db library "/lib/arm-linux-gnueabihf/libthread_db.so.1".
>> Program received signal SIGILL, Illegal instruction.
>> D2/5: G_file_name(): path = /home/epi/Envs/grass7data/nc_spm_08_grass7/PERMANENT
>> Description:
>>  Performs stream network extraction.
>> Keywords:
>>  raster, hydrology, stream network
>> Usage:
>>  r.stream.extract elevation=name [accumulation=name] [depression=name]
>>    threshold=value [d8cut=value] [mexp=value] [stream_length=value]
>>    [memory=value] [stream_rast=name] [stream_vect=name] [direction=name]
>>    [--overwrite] [--verbose] [--quiet]
>> Flags:
>>  --o   Allow output files to overwrite existing files
>>  --v   Verbose module output
>>  --q   Quiet module output
>> Parameters:
>>       elevation   Name of input elevation raster map
>>    accumulation   Name of input accumulation raster map
>>                    Stream extraction will use provided accumulation instead of calculating it a new
>>      depression   Name of raster map with real depressions
>>                    Streams will not be routed out of real depressions
>>       threshold   Minimum flow accumulation for streams
>>                    Must be > 0
>>           d8cut   Use SFD above this threshold
>>                    If accumulation is larger than d8cut, SFD is used instead of MFD. Applies only if no accumulation map is given.
>>                   default: infinity
>>            mexp   Montgomery exponent for slope, disabled with 0
>>                    Montgomery: accumulation is multiplied with pow(slope,mexp) and then compared with threshold.
>>                   default: 0
>>   stream_length   Delete stream segments shorter than stream_length cells.
>>                    Applies only to first-order stream segments (springs/stream heads).
>>                   default: 0
>>          memory   Maximum memory to be used in MB
>>                   default: 300
>>     stream_rast   Name for output raster map with unique stream ids
>>     stream_vect   Name for output vector map with unique stream ids
>>       direction   Name for output raster map with flow direction
>> ERROR: Option <elevation> does not accept multiple answers
>> [Inferior 1 (process 7565) exited with code 01]
>> (gdb)
>> On Dec 6, 2013, at 4:32 PM, epi <massimodisasha at gmail.com> wrote:
>>> Hi !
>>> this the output of gdb :
>>> 0x2c966e68 in ?? () from /usr/lib/arm-linux-gnueabihf/libcrypto.so.1.0.0
>>> (gdb)
>>> Thanks for your help!
>>> Massimo.
>>> On Dec 6, 2013, at 4:16 PM, Rashad M <mohammedrashadkm at gmail.com> wrote:
>>>> Hello Massimo,
>>>> A gdb output could be more helpful for a segfault
>>>> On Fri, Dec 6, 2013 at 7:06 PM, epi <massimodisasha at gmail.com> wrote:
>>>> Hi,
>>>> i’m trying to run  “r.stream.extract” on a little linux machine, i got got grass up and running on a small quad-core Arm 1gb ram
>>>> OS :  Debian SID ArmHF.
>>>> the command i’m using is :
>>>> r.stream.extract elevation=elevation at PERMANENT accumulation=accum threshold=40 stream_rast=stream_network stream_vect=streams --o --q
>>>> location :  nc_spm_08_grass7/PERMANENT/
>>>> i set the debug level to 5, this the segfault log :
>>>> https://gist.github.com/epifanio/7829206
>>>> if helpful, this is the log of make clean and make :
>>>> https://gist.github.com/epifanio/7829256
>>>> On other platform (same grass and r.stream.extract version it wks just fine)
>>>> Have you any idea on what’s wrong ?
>>>> Thanks,
>>>> Massimo.
>>>> _______________________________________________
>>>> grass-dev mailing list
>>>> grass-dev at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/grass-dev
>>>> Regards,
>>>>    Rashad
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20131206/16a65586/attachment-0001.html>
