[GRASS-dev] segfault on 'r.stream.extract' - debian armh
Maris Nartiss
maris.gis at gmail.com
Fri Dec 6 15:36:56 PST 2013
Any warnings during compilation?
Try to compile with -g and -O0 to get slow but debugging-friendly version.
When program gets stopped by SIGILL in gdb, issue "bt" command to get backtrace.
No help form me, but more info never hurts ;)
Maris.
2013/12/6 epi <massimodisasha at gmail.com>:
> Hi !
> this the output of gdb :
> Starting program: /home/epi/Envs/env1/grass-7.0.svn/bin/r.stream.extract
> .stream.extract elevation=elevation50m at PERMANENT accumulation=accum
> threshold=40 stream_rast=stream_network stream_vect=streams --o
> [Thread debugging using libthread_db enabled]
> Using host libthread_db library
> "/lib/arm-linux-gnueabihf/libthread_db.so.1".
> Program received signal SIGILL, Illegal instruction.
> 0x2c966e68 in ?? () from /usr/lib/arm-linux-gnueabihf/libcrypto.so.1.0.0
> (gdb)
> Thanks for your help!
> Massimo.
> On Dec 6, 2013, at 4:16 PM, Rashad M <mohammedrashadkm at gmail.com> wrote:
> Hello Massimo,
> A gdb output could be more helpful for a segfault
> On Fri, Dec 6, 2013 at 7:06 PM, epi <massimodisasha at gmail.com> wrote:
>> Hi,
>> i’m trying to run “r.stream.extract” on a little linux machine, i got got
>> grass up and running on a small quad-core Arm 1gb ram
>> OS : Debian SID ArmHF.
>> the command i’m using is :
>> r.stream.extract elevation=elevation at PERMANENT accumulation=accum
>> threshold=40 stream_rast=stream_network stream_vect=streams --o --q
>> location : nc_spm_08_grass7/PERMANENT/
>> i set the debug level to 5, this the segfault log :
>> https://gist.github.com/epifanio/7829206
>> if helpful, this is the log of make clean and make :
>> https://gist.github.com/epifanio/7829256
>> On other platform (same grass and r.stream.extract version it wks just
>> fine)
>> Have you any idea on what’s wrong ?
>> Thanks,
>> Massimo.
>> grass-dev mailing list
>> grass-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-dev
> Regards,
> Rashad
