[GRASS-dev] segfault on 'r.stream.extract' - debian armh
epi
massimodisasha at gmail.com
Sat Dec 7 10:15:41 PST 2013
Hi Glynn,
thanks for the detailed explanation!
is there something i can try ?
perhaps, build gdal from src and disabling postgresql support ?
Thanks a lot!
Massimo.
this a copy of the gdb-backtrace :
(gdb) exec-file r.stream.extract elevation=elevation50m at PERMANENT accumulation=accum threshold=40 stream_rast=stream_network stream_vect=streams --o
(gdb) r
Starting program: /home/epi/Envs/env1/grass-7.0.svn/bin/r.stream.extract
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib/arm-linux-gnueabihf/libthread_db.so.1".
Program received signal SIGILL, Illegal instruction.
0x2c99fe68 in ?? () from /usr/lib/arm-linux-gnueabihf/libcrypto.so.1.0.0
(gdb) bt
#0 0x2c99fe68 in ?? () from /usr/lib/arm-linux-gnueabihf/libcrypto.so.1.0.0
Cannot access memory at address 0x0
#1 0x2c99db2c in OPENSSL_cpuid_setup ()
#2 0x2aab60d6 in call_init (env=0x7efff35c, argv=0x7efff354, argc=1,
l=<optimized out>) at dl-init.c:84
#3 call_init (l=<optimized out>, argc=1, argv=0x7efff354, env=0x7efff35c)
at dl-init.c:34
#4 0x2aab6158 in _dl_init (main_map=0x2aaca958, argc=1, argv=0x7efff354,
env=0x7efff35c) at dl-init.c:133
#5 0x2aaabc62 in _dl_start_user () from /lib/ld-linux-armhf.so.3
#6 0x2aaabc62 in _dl_start_user () from /lib/ld-linux-armhf.so.3
Backtrace stopped: previous frame identical to this frame (corrupt stack?)
(gdb)
On Dec 6, 2013, at 7:24 PM, Glynn Clements <glynn at gclements.plus.com> wrote:
> epi wrote:
>> googling �
>> is it possible that in :
>> http://svn.osgeo.org/grass/grass/trunk/raster/r.stream.extract/
>> there may be some assembly code that gets executed which won't work under armhf ?
> GRASS doesn't use assembly. And the SIGILL is reported as occurring in
> libcrypto, not in the GRASS code.
> The libcrypto dependency typically exists because GDAL links to libpq
> (PostgreSQL client library) which uses libcrypto for certain
> authentication methods.
> libcrypto probably isn't even being used in this situation, so I
> suspect that a bug is causing either a function pointer or a return
> address to be corrupted, resulting in a jump to a random memory
> location which just happens to be inside libcrypto.
> As r.stream.extract is relatively new, it's possible that it hasn't
> seen significant testing on platforms other than x86 and x86-64. Apart
> from anything else, alignment bugs won't show up on those platforms
> (x86 supports unaligned access, ARM doesn't AFAIK).
