[GRASS-dev] Is the dash a Mapset naming restriction?
Maris Nartiss
maris.gis at gmail.com
Sun Dec 8 01:32:59 PST 2013
As dash in some contexts (hypothetically) can be interpreted as a
minus sign (pre minus processing), I would say it's a bug that you
were able to create a mapset with such name.
Just open a ticket in trac for the tool you used to create mapset.
Maris.
2013/12/8 Nikos Alexandris <nik at nikosalexandris.net>:
> "g.mlist rast pat=hpf* mapset=pre-processing_post"
> gives a "Segmentation fault". Is the dash an unwanted character in naming
> Mapsets? I don't see a segfault with "normal" Mapset names.
> Nikos
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
