[GRASS-dev] [GRASS GIS] #2141: Linking or importing raster with non-ascii characters in filename fails in wxGUI with UnicodeEncodeError
trac at osgeo.org
Sun Dec 8 02:01:46 PST 2013
Reporter: torsti | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: wxGUI | Version: svn-trunk
Keywords: | Platform: Linux
Cpu: x86-64 |
GRASS SVN Revision: 58403
When attempting to import or link a raster with a non-ascii basename the
wxGUI dialog, after selecting the file, does not provide a layer for
selection.
Traceback from Command console output from r.external, but same happens
with r.in.gdal:
File "/usr/lib/python2.7/dist-
packages/wx-2.8-gtk2-unicode/wx/lib/filebrowsebutton.py",
line 140, in OnChanged
self.changeCallback(evt)
File "/usr/local/grass-7.0.svn/etc/gui/wxpython/gui_core/g
select.py", line 1813, in OnUpdate
self._reloadLayers()
select.py", line 1849, in _reloadLayers
grassName = GetValidLayerName(baseName.split('.', -1)[0])
File
"/usr/local/grass-7.0.svn/etc/gui/wxpython/core/utils.py",
line 201, in GetValidLayerName
retName = str(name).strip()
UnicodeEncodeError
'ascii' codec can't encode character u'\xf6' in position 18:
ordinal not in range(128)
The filename in question:
`/home/torsti/lähdeaineistot/Kansalliskirjasto/pitäjänkartta/VVJ/670-253 -
1945 - Röykkä - 1.tif`. The $GISDBASE path does not contain non-ascii
characters and importing/linking files where any path component except the
filename/basename contains non-ascii characters does work, e.g. importing
the same file with `Roykka` substituted for `Röykkä` is ok.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2141>
