[GRASS-dev] Dash vs Bash changes in GRASS GIS
Markus Neteler
neteler at osgeo.org
Mon Dec 9 00:22:32 PST 2013
On Sun, Dec 8, 2013 at 11:50 PM, Rashad M <mohammedrashadkm at gmail.com> wrote:
> Hi all,
> Will the shell change to dash from bash in linux affect any GRASS startup
> scripts now ? Are they all ported to dash?
Note that dash is Ubuntu specific (and/or Debian, no idea).
For example, on Fedora there is
/bin/sh -> bash
> Most of scripts worked with bash
> doesn't work with dash and Ubuntu changed to dash by default. So when
> referring to /bin/sh its actually /bin/dash and loops and some increment
> operators wont work with dash.
The overall idea in GRASS is to avoid bash-isms at all and to stick to Bourne
shell syntax.
> So does GRASS GIS sets its shell to be
> bash/dash shell instead of /bin/sh which in some distro maybe bash and dash
> in others.
While ideally all scripts should be Bourne shell a few are explicitely
bash scripts [1] or not properly ported (in case to be fixed!).
Markus
[1] result of find/grep in G65:
./mswindows/osgeo4w/msys.bat:start "%WD%mintty" /bin/bash -l
./tools/sql.sh:#!/bin/bash
./lib/init/init.sh: export SHELL=/usr/bin/bash.exe
./lib/vector/dglib/examples/rtest03.sh:#!/bin/bash
./scripts/r.tileset/r.tileset:#!/bin/bash
./scripts/i.spectral/i.spectral:#!/bin/bash
./vector/v.clean/test/v.clean.test:#!/bin/bash
--> essentially only r.tileset and i.spectral
