[GRASS-dev] GDAL,GRASS 7 and PostGIS on Ubunutu 12.04
Blumentrath, Stefan
Stefan.Blumentrath at nina.no
Wed Dec 11 03:26:03 PST 2013
Dear all,
Do not know if this post belongs here or to PostGIS:
I compiled GDAL (rev 26701) with support for GRASS 7 (not the plugin but recompiled GDAL with GRASS support after building GRASS 7 from source (rev 58438)).
gdalinfo --formats gives:
Supported Formats:
GRASS (ro):
(no version info in output)
I do have both
/usr/local/grass-7.0.svn/lib
/usr/local/grass-6.4.4svn/lib
In /etc/ld.so.conf (in that order).
gdal_translate gives a warning message:
Warning 1: GRASS warning: GISBASE enviroment variable was not set, using:
However, it takes GRASS raster gladly, so that works.
Then I build PostGIS 2.1.2 against the compiled GDAL version with GRASS support.
Unfortunately raster2pgsql gives error messages when I try to feed GRASS raster:
"Segmentation fault (core dumped)"
After I removed the link to GRASS 6.4.4svn/lib in /etc/ld.so.conf the errormessage changes to:
ERROR 1: libgrass_I.so: cannot open shared object file: No such file or directory
*** glibc detected *** raster2pgsql: corrupted double-linked list: 0x00000000012e59f0 ***
Any Ideas?
Cheers
Stefan
