[GRASS-dev] trying to compile GRASS 6.5 on Mavericks
Michael Barton
Michael.Barton at asu.edu
Thu Dec 12 22:30:35 PST 2013
Drat!
GRASS 6.5 does not compile. Configure is OK, using the same string as I just used for GRASS 7. But all modules generate an error during compilation. Here is an example.
Finished compilation: Thu Dec 12 23:19:50 MST 2013
make: *** [default] Error 1
Michaels-MacBook-Air-2:grass6_dev cmbarton$ cd /Users/cmbarton/Dropbox/GRASS_dropbox/source/grass6_dev/lib/gis
Michaels-MacBook-Air-2:gis cmbarton$ make
gcc -I/Users/cmbarton/Dropbox/GRASS_dropbox/source/grass6_dev/dist.x86_64-apple-darwin13.0.0/include -g -O2 -arch i386 -arch x86_64 -isysroot /Developer/SDKs/MacOSX10.7.sdk -fno-common -DPACKAGE=\""grasslibs"\" -D_FILE_OFFSET_BITS=64 -DGDAL_LINK=1 -DGDAL_DYNAMIC=1 -DPACKAGE=\""grasslibs"\" -I/Library/Frameworks/PROJ.framework/unix/include -I/Library/Frameworks/GDAL.framework/Versions/1.10/Headers -I/Library/Frameworks/GDAL.framework/Versions/1.10/Headers -I/Users/cmbarton/Dropbox/GRASS_dropbox/source/grass6_dev/dist.x86_64-apple-darwin13.0.0/include -o OBJ.x86_64-apple-darwin13.0.0/error.o -c error.c
error.c:281:6: error: non-void function 'print_error' should return a value [-Wreturn-type]
return;
1 error generated.
make: *** [OBJ.x86_64-apple-darwin13.0.0/error.o] Error 1
Michael
____________________
C. Michael Barton
Director, Center for Social Dynamics & Complexity
Professor of Anthropology, School of Human Evolution & Social Change
Arizona State University
voice: 480-965-6262 (SHESC), 480-965-8130/727-9746 (CSDC)
fax: 480-965-7671 (SHESC), 480-727-0709 (CSDC)
www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20131213/ad27a060/attachment.html>
