[GRASS-dev] 6.4.4 planning
Michael Barton Michael.Barton at asu.edu
Tue Dec 17 14:02:05 PST 2013
I started compiling GRASS 6.4, release branch last Friday but was only able to test it today. It seems to work fine under Mavericks for Mac.
Here are a couple a minor issues I noticed.
When I first tried to use nviz (3D display), it failed, with an error message in the console. But it worked fine every time since then, even after restarting GRASS.
Also, there is chatter in the terminal on opening nviz.
GRASS_INFO_MESSAGE(75334,4): Loading raster map <elevation at PERMANENT>...
GRASS_INFO_END(75334,4)
GRASS_INFO_PERCENT: 0
GRASS_INFO_PERCENT: 3
GRASS_INFO_PERCENT: 6
GRASS_INFO_PERCENT: 9
and
GRASS_INFO_MESSAGE(75334,6): Translating colors from raster map <elevation at PERMANENT>...
GRASS_INFO_END(75334,6)
Probably a simple fix if you know where to find it.
MIchael
______________________________
C. Michael Barton
Director, Center for Social Dynamics & Complexity
Professor of Anthropology, School of Human Evolution & Social Change
Arizona State University
Tempe, AZ  85287-2402
USA
voice:  480-965-6262 (SHESC), 480-965-8130/727-9746 (CSDC)
fax:          480-965-7671(SHESC), 480-727-0709 (CSDC)
www:  http://csdc.asu.edu, http://shesc.asu.edu
http://www.public.asu.edu/~cmbarton
On Dec 12, 2013, at 11:32 PM, Michael Barton <Michael.Barton at asu.edu<mailto:Michael.Barton at asu.edu>> wrote:
At the moment, GRASS 6.5 is not compiling on the Mac under OS X 10.9 (Mavericks).
Michaesl
C. Michael Barton
fax:          480-965-7671 (SHESC),  480-727-0709 (CSDC)
www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu<http://csdc.asu.edu/>
On Dec 12, 2013, at 11:23 PM, grass-dev-request at lists.osgeo.org<mailto:grass-dev-request at lists.osgeo.org> wrote:
From: Markus Neteler <neteler at osgeo.org<mailto:neteler at osgeo.org>>
Subject: Re: [GRASS-dev] 6.4.4 planning
Date: December 12, 2013 at 3:01:22 PM MST
To: GRASS developers list <grass-dev at lists.osgeo.org<mailto:grass-dev at lists.osgeo.org>>
On Sun, Nov 24, 2013 at 4:32 PM, Helmut Kudrnovsky <hellik at web.de<mailto:hellik at web.de>> wrote:
Markus Neteler wrote
On Sat, Nov 16, 2013 at 3:00 AM, Hamish
on the grass-user ML Markus N wrote:
(and it is time to get 6.4.4 out...)
"Important bugs concerning the next release"
 https://trac.osgeo.org/grass/report/13
see http://trac.osgeo.org/grass/ticket/2138 for the actual state of python
addons in winGRASS6.5.svn/6.4.svn.
we are near to working python addon scripts in winGRASS :-)
this seem to be the one and only thing blocking 6.4.4RC1...
Any suggestions to get it done?
Markus
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20131217/5c94bf3f/attachment-0001.html>
