[GRASS-dev] trying to compile GRASS 6.5 on Mavericks
Michael Barton Michael.Barton at asu.edu
Sat Dec 21 12:49:28 PST 2013
Has this been fixed yet so I can compile 6.5?
Thanks
____________________
C. Michael Barton
Director, Center for Social Dynamics & Complexity
Professor of Anthropology, School of Human Evolution & Social Change
Arizona State University
voice: 	480-965-6262 (SHESC), 480-965-8130/727-9746 (CSDC)
fax:          480-965-7671 (SHESC),  480-727-0709 (CSDC)
www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
On Dec 14, 2013, at 7:19 AM, Glynn Clements <glynn at gclements.plus.com> wrote:
> Michael Barton wrote:
>>>> GRASS 6.5 does not compile. Configure is OK, using the same string
>>>> as I just used for GRASS 7. But all modules generate an error during
>>>> compilation. Here is an example.
>>>> error.c:281:6: error: non-void function 'print_error' should return a value [-Wreturn-type]
>>>>           return;
>>> Change it to "return 0;". The return value is ignored in any case (in
>>> GRASS 7, print_error() returns void).
>> Is this something that needs to be changed in the make file?
> No; lib/gis/error.c, line 281.
