[GRASS-dev] [GRASS GIS] #2147: db.databases not working in GRASS 7
GRASS GIS trac at osgeo.org
Sun Dec 22 14:49:05 PST 2013
 Reporter:  cmbarton              |       Owner:  grass-dev@…
     Type:  defect                |      Status:  new
 Priority:  normal                |   Milestone:  7.0.0
Component:  Database              |     Version:  svn-trunk
 Keywords:  db.databases, sqlite  |    Platform:  All
      Cpu:  OSX/Intel             |
Comment(by neteler):
 Replying to [comment:5 martinl]:
 > Replying to [comment:4 neteler]:
 > > GRASS 7.0.svn (nc_spm_08):~ > db.databases
 > > D1/1: db_d_init_error(): SQLite
 > > D1/1: db count = 0
 > > No databases found
 > The command
 > db.connect -d
 > D1/1: Creating new default DB params with db_set_default_connection()
 > Default driver / database set to:
 > driver: sqlite
 > database: $GISDBASE/$LOCATION_NAME/$MAPSET/sqlite/sqlite.db
 > doesn't create database, so `db.databases` doesn't list any
 > database. You need to run command which writes attribute data
 > to the database.
 Good point.
 Maybe "db.connect -d" should create the (empty) sqlite.db file to
 avoid user confusion.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2147#comment:6>
