[GRASS-dev] [GRASS GIS] #2148: wxGUI modeler: allow to name elements in the model schema
GRASS GIS trac at osgeo.org
Wed Dec 25 08:28:43 PST 2013
 Reporter:  mlennert           |       Owner:  grass-dev@…
     Type:  enhancement        |      Status:  new
 Priority:  normal             |   Milestone:  7.0.0
Component:  wxGUI              |     Version:  svn-trunk
 Keywords:  modeller comments  |    Platform:  Unspecified
      Cpu:  Unspecified        |
Comment(by martinl):
 Replying to [ticket:2148 mlennert]:
 > It would be nice if by changing the name of an object in the Objects
 tab, this name would replace the name of the command in the model display.
 Currently setting this name just is ignored and is lost after saving and
 reopening the model.
 it was hopefully fixed in r58518, you can set action name/label in 'Items'
 tab or from contextual menu ('Set label').
 > In addition, the possibility to add comments would be nice, possibly in
 the form of a comment object that would be ignored in the model.
 This has been implemented in r58521. You can set comments from contextual
 menu, it's saved to model file. I am not sure how to display them,
 probably as tooltips or directly in the object shape below label. Any
 opinions?
Ticket URL: <http://trac.osgeo.org/grass/ticket/2148#comment:1>
