[GRASS-dev] v.clean problem with rmarea (ERROR: Area merging failed)
Yann Chemin
ychemin at gmail.com
Tue Dec 31 00:25:38 PST 2013
Projection is in meters...
projection: 1 (UTM)
zone: 26
datum: wgs84
ellipsoid: wgs84
north: 1666020
south: 1639095
west: 767715
east: 794535
nsres: 15
ewres: 15
rows: 1795
cols: 1788
cells: 3209460
On 31 December 2013 09:53, Yann Chemin <ychemin at gmail.com> wrote:
> Hi,
> (SVN G7)
> it does work with thres inferior to 600, but not above...
> v.clean input=vnir4567_seg_0 output=vnir4567_seg_0_no_small_areas
> type=area tool=rmarea thres=10000.00 --overwrite
> Tool: Threshold
> Remove small areas: 10000
> WARNING: Vector map <vnir4567_seg_0_no_small_areas> already exists and
> will be overwritten
> Copying features...
> Rebuilding parts of topology...
> Building topology for vector map <vnir4567_seg_0_no_small_areas at PERMANENT
> Registering primitives...
> 19070 primitives registered
> 187624 vertices registered
> Building areas...
> 5344 areas built
> 251 isles built
> Attaching islands...
> Attaching centroids...
> Number of nodes: 8636
> Number of primitives: 19070
> Number of points: 0
> Number of lines: 0
> Number of boundaries: 13729
> Number of centroids: 5341
> Number of areas: 5344
> Number of isles: 251
> Tool: Remove small areas
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20131231/bf55e578/attachment.html>
