[GRASS-dev] formatting expressions for r.mapcalc in GRASS6.4.3
Markus Neteler neteler at osgeo.org
Fri Feb 1 11:58:46 PST 2013
On Fri, Feb 1, 2013 at 4:16 AM, Helena Mitasova <hmitaso at ncsu.edu> wrote:
> Over the years there have been changes in the formatting of r.mapcalc expressions
> and it appears the currently there is no single way that would work everywhere
I use it for a long time and have a standard formatting which always works...
> GRASS 6.4.3RC2 (nc_spm_08):~ > r.mapcalc result = 'elevation * 2'
I use and recommend:
r.mapcalc "result = elevation * 2"
Note:
- space before and after = like this it is GRASS 7 compliant
- " expression ...": avoiding the single ' you can use shell variable
expansion like
  VAR1=2.0
  r.mapcalc "result = elevation * $VAR1"
Like this you are fine with GRASS7, too.
Markus
