[GRASS-dev] grass-dev Digest, Vol 83, Issue 58
Michael Barton
Michael.Barton at asu.edu
Sun Feb 3 11:15:51 PST 2013
A bit more testing. I found the "render" button. After doing this a forcing a rendering, the animation made it through all 401 maps.
Michael
____________________
C. Michael Barton
Director, Center for Social Dynamics & Complexity
Professor of Anthropology, School of Human Evolution & Social Change
Arizona State University
voice: 480-965-6262 (SHESC), 480-727-9746 (CSDC)
fax: 480-965-7671 (SHESC), 480-727-0709 (CSDC)
www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
On Feb 3, 2013, at 11:48 AM, Michael Barton <michael.barton at asu.edu<mailto:michael.barton at asu.edu>> wrote:
I just tested the animation module in trunk.
It does not crash and works fine up to image 179 out of 401. After that, the screen is blank with a "no data" message. There is data. Could this be a limit to the number of files that can be parsed (or number of characters)?
Michael
C. Michael Barton
www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu<http://csdc.asu.edu/>
On Jan 31, 2013, at 10:51 AM, grass-dev-request at lists.osgeo.org<mailto:grass-dev-request at lists.osgeo.org> wrote:
From: Anna Kratochvílová <kratochanna at gmail.com<mailto:kratochanna at gmail.com>>
Subject: Re: [GRASS-dev] animations on Mac problem
Date: January 31, 2013 9:58:57 AM MST
To: Helena Mitasova <hmitaso at ncsu.edu<mailto:hmitaso at ncsu.edu>>
Cc: Michael Barton <Michael.Barton at asu.edu<mailto:Michael.Barton at asu.edu>>, GRASS developers list <grass-dev at lists.osgeo.org<mailto:grass-dev at lists.osgeo.org>>, Thomas Adams - NOAA Federal <thomas.adams at noaa.gov<mailto:thomas.adams at noaa.gov>>
On Thu, Jan 31, 2013 at 5:09 PM, Helena Mitasova <hmitaso at ncsu.edu<mailto:hmitaso at ncsu.edu>> wrote:
This is the error that I get when I try to run the animation (on MacOSX10.6 - I will try on 10.8 as well later on):
Could you test it again, I've just committed a small change which could help.
Anna
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20130203/41b8e09f/attachment-0001.html>
