[GRASS-dev] [GRASS GIS] #1865: WinGrass v.buffer memory issue
GRASS GIS trac at osgeo.org
Mon Feb 4 06:32:09 PST 2013
 Reporter:  feppink  |       Owner:  grass-dev@…
     Type:  defect   |      Status:  new
 Priority:  normal   |   Milestone:  6.4.3
Component:  Vector   |     Version:  6.4.3 RCs
 Keywords:           |    Platform:  MSWindows 7
      Cpu:  x86-64   |
Comment(by mmetz):
 Replying to [comment:1 feppink]:
 > Additional info: I specify no other options for v.buffer apart from the
 units for the major axis. Memory issue starts occurring during "Breaking
 boundaries".
 If possible, try GRASS 7, because v.buffer only works correctly in GRASS 7
 and vector memory consumption is much less.
 Can you make the input vector map available and post the exact command
 used to calculate buffers?
 Markus M
Ticket URL: <https://trac.osgeo.org/grass/ticket/1865#comment:2>
