[GRASS-dev] does GRASS 7 for Mac compile yet?
Anna Kratochvílová
kratochanna at gmail.com
Tue Feb 5 00:46:36 PST 2013
On Mon, Feb 4, 2013 at 11:57 PM, epi <massimodisasha at gmail.com> wrote:
> i'm trying to debug the build of GRASS 7 on mac OSX 10.8.x in 64 bit with WX
> 2.9.x
> After commenting the check for wx version i got the GUI start, some worning
what exactly is the problem with the 'check for wx version'? The
warning (wx.InitAllImageHandlers) and the PrepareDC error should be
fixed now.
Anna
> GRASS 7.0.svn (spearfish60):~ >
> /usr/local/grass-7.0.svn/etc/gui/wxpython/wxgui.py:54:
> wxPyDeprecationWarning: Call to deprecated item 'InitAllImageHandlers'.
> wx.InitAllImageHandlers()
> /usr/local/grass-7.0.svn/etc/gui/wxpython/gui_core/goutput.py:230:
> wxPyDeprecationWarning: Call to deprecated item 'SetVirtualSizeHints'.
> outputSizer.SetVirtualSizeHints(self.panelOutput)
> the Window Manager seems to work properly (i cal load a layer Rast/Vect in
> the lkayer tree, the shell also pront out the log of commands nicely)
> but i can't display layers (both Vector and Raster are not displayed).
> Commenting this 2 line in madisp.py :
> 359 #self.PrepareDC(dc)
> 519 #self.PrepareDC(dc)
> i got the Raster map displaying properly
> but no vector, the error is in a missed Cairo Driver :
> /usr/local/grass-7.0.svn/etc/gui/wxpython/gui_core/ghelp.py:
> 608: wxPyDeprecationWarning: Call to deprecated item
> Command 'd.vect map=archsites at PERMANENT
> type=point,line,area,face' failed
> Details: Unknown display driver <cairo>
> I wasn't able to get the cairo driver working during the Make step, it shows
> the error at the end of the log [1]
> about a missed arch ... but i guess ... I have everything built as
> --universal
> In doubt I rebuilt fontconfig and cairo and checked the relative
> architecture :
> lipo -info /usr/local/Cellar/cairo/1.12.12/lib/cairo/libcairo-trace.0.dylib
> /usr/local/Cellar/cairo/1.12.12/lib/libcairo-gobject.2.dylib
> /usr/local/Cellar/cairo/1.12.12/lib/libcairo-script-interpreter.2.dylib
> /usr/local/Cellar/cairo/1.12.12/lib/libcairo.2.dylib
> Architectures in the fat file:
> /usr/local/Cellar/cairo/1.12.12/lib/cairo/libcairo-trace.0.dylib are: i386
> x86_64
> /usr/local/Cellar/cairo/1.12.12/lib/libcairo-gobject.2.dylib are: i386
> x86_64
> /usr/local/Cellar/cairo/1.12.12/lib/libcairo-script-interpreter.2.dylib are:
> i386 x86_64
> /usr/local/Cellar/cairo/1.12.12/lib/libcairo.2.dylib are: i386 x86_64
> epi:~ epi$
> /usr/local/Cellar/fontconfig/2.10.91/bin/fc-cache: Mach-O universal
> binary with 2 architectures
> /usr/local/Cellar/fontconfig/2.10.91/bin/fc-cache (for architecture i386):
> Mach-O executable i386
> /usr/local/Cellar/fontconfig/2.10.91/bin/fc-cache (for architecture x86_64):
> Mach-O 64-bit executable x86_64
> /usr/local/Cellar/fontconfig/2.10.91/bin/fc-cat: Mach-O universal
> /usr/local/Cellar/fontconfig/2.10.91/bin/fc-cat (for architecture i386):
> /usr/local/Cellar/fontconfig/2.10.91/bin/fc-cat (for architecture x86_64):
> /usr/local/Cellar/fontconfig/2.10.91/bin/fc-list: Mach-O universal
> /usr/local/Cellar/fontconfig/2.10.91/bin/fc-list (for architecture i386):
> /usr/local/Cellar/fontconfig/2.10.91/bin/fc-list (for architecture x86_64):
> /usr/local/Cellar/fontconfig/2.10.91/bin/fc-match: Mach-O universal
> /usr/local/Cellar/fontconfig/2.10.91/bin/fc-match (for architecture i386):
> /usr/local/Cellar/fontconfig/2.10.91/bin/fc-match (for architecture x86_64):
> /usr/local/Cellar/fontconfig/2.10.91/bin/fc-pattern: Mach-O universal
> /usr/local/Cellar/fontconfig/2.10.91/bin/fc-pattern (for architecture i386):
> x86_64): Mach-O 64-bit executable x86_64
> /usr/local/Cellar/fontconfig/2.10.91/bin/fc-query: Mach-O universal
> /usr/local/Cellar/fontconfig/2.10.91/bin/fc-query (for architecture i386):
> /usr/local/Cellar/fontconfig/2.10.91/bin/fc-query (for architecture x86_64):
> /usr/local/Cellar/fontconfig/2.10.91/bin/fc-scan: Mach-O universal
> /usr/local/Cellar/fontconfig/2.10.91/bin/fc-scan (for architecture i386):
> /usr/local/Cellar/fontconfig/2.10.91/bin/fc-scan (for architecture x86_64):
> /usr/local/Cellar/fontconfig/2.10.91/bin/fc-validate: Mach-O universal
> /usr/local/Cellar/fontconfig/2.10.91/bin/fc-validate (for architecture
> i386): Mach-O executable i386
> x86_64):Mach-O 64-bit executable x86_64
> They are multi-arch, but unlucky i still have the same error in cairodriver,
> [1] http://epi.whoi.edu/esr/grass7_cairodriver_log.txt <-- full build log
> William K. helped me to debug the error,
> and seems that the GRASS Configure is not storing the fontconfig linking in
> platform.make so it doesn't get into the cairo driver compilation.
> thanks for helping me,
> Massimo.
> Il giorno 31/gen/2013, alle ore 13:04, Michael Barton
> <michael.barton at asu.edu> ha scritto:
> It may work with wxPython 2.9 but nobody has been able to test yet.
> Michael
> ______________________________
> C. Michael Barton
> Director, Center for Social Dynamics & Complexity
> Professor of Anthropology, School of Human Evolution & Social Change
> Arizona State University
> Tempe, AZ 85287-2402
> USA
> voice: 480-965-6262 (SHESC), 480-727-9746 (CSDC)
> fax: 480-965-7671(SHESC), 480-727-0709 (CSDC)
> www: http://csdc.asu.edu, http://shesc.asu.edu
> http://www.public.asu.edu/~cmbarton
> On Jan 31, 2013, at 3:47 AM, epi <massimodisasha at gmail.com>
> wrote:
> I'm a mac user as well and i will be happy to help,
> … i built grass weekly (if not daily) in the past,
> but unfortunately now i'm on mac 10.8.x using 64bit python, all my python
> packages numpy scipy etc etc etc .. are 64 bit and ...
> WX gui
> <start-joke>
> great choice
> </end-joke>
> unfortunately doesn't works on mac in 64 bit mode … i'm waiting the 2.9.x to
> be stable that is 2 years now ...
> This IMO can be one of the major reason of "lack of mac-man-dev-power"
> i can provide log on the build of grass7 (without gui modules) … but this
> doesn't help
> i don't know if grass-gui-dev want try to test grass with wx-2.9 .. it is
> unstable but works, if yes .. i'll be happy to be a guinea pig
> --Massimo
> Il giorno 31/gen/2013, alle ore 05:32, Thomas Adams - NOAA Federal
> <thomas.adams at noaa.gov> ha scritto:
> All,
> I'm a Mac user in addition to Linux. I'm going to have more free time
> starting in a few weeks. I'd be happy to step-up my use of GRASS 7 for
> testing. Just let me know what I can do. I'm moving from the U.S. to
> Melbourne, Australia in a couple of weeks!
> Cheers,
> Tom
> On Thu, Jan 31, 2013 at 5:27 AM, Luca Delucchi <lucadeluge at gmail.com> wrote:
>> 2013/1/31 Margherita Di Leo <dileomargherita at gmail.com>:
>> > I think we should consider to promote a fund rising for buying a (used,
>> > discounted, whatever) mac computer for the use of developers who are
>> > developing or are willing to test on it. What do you think?
>> I don't like this idea.
>> I think should be really better to have some more Mac power user
>> instead, and use the money for community sprint
>> > my 2 c
>> > madi
>> ciao
>> Luca
>> http://gis.cri.fmach.it/delucchi/
>> www.lucadelu.org
>> grass-dev mailing list
>> grass-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-dev
> Thomas E Adams
> Development & Operations Hydrologist
> National Weather Service
> Ohio River Forecast Center
> 1901 South State Route 134
> Wilmington, OH 45177
> http://www.erh.noaa.gov/er/ohrfc/
> EMAIL: thomas.adams at noaa.gov
> VOICE: 937-383-0528
> FAX: 937-383-0033
