[GRASS-dev] GRASS6.4.3RC2 issues
Anna Kratochvílová kratochanna at gmail.com
Tue Feb 5 10:17:33 PST 2013
On Tue, Jan 22, 2013 at 2:47 AM, Helena Mitasova <hmitaso at ncsu.edu> wrote:
> - in 2D display legend is now much better than ever before, but
> when the d.legend command is run from command line
> it appears that the legend parameters are not carried over to the GUI
> and need to be entered in GUI again - is this the desired behavior?
> For example in the sequence
> # Convert from vector to raster
> in this assignment
> http://courses.ncsu.edu/mea582/common/GIS_anal_grass/GIS_Anal_grdataS2.html
> this command does not work properly from the command line
> d.legend streets_speed_30m at=5,30,2,5 use=25,35,45,55,65
> Also, if there is a legend already present, "Add legend" opens the legend GUI
> behind the map display window (where it is of course hard to find)
> I think this issue has already been discussed before
> BTW, the legend now runs on Mac in 3d wxnviz well.
Please try to test, I made larger changes and I hope I didn't create
any new problem.
> - g.remove run from command console thinks I am in PERMANENT rather than the current mapset
I was not able to reproduce it, anyone else?
Anna
> g.remove rast=elev_lidrural1mr_1m
> Removing raster <elev_lidrural1mr_1m>
> WARNING: Raster map <elev_lidrural1mr_1m> not found
> WARNING: <elev_lidrural1mr_1m> nothing removed
> from linux shell it works
> GRASS 6.4.3RC2 (nc_spm_08):~ > g.remove rast=elev_lidruralmr_1m
> Removing raster <elev_lidruralmr_1m>
