[GRASS-dev] [GRASS GIS] #1874: latitudinal bias in sample points created with r.random
Paulo van Breugel p.vanbreugel at gmail.com
Thu Feb 7 02:55:36 PST 2013
Not only in theory, I actually use it all the time :-). And you can
achieve the same by setting all the areas outside your target area to
NULL. I like how the combination of the two gives you a fine control
over how you want to sample an area. You can even do the same with the
cover layer. Although to be honest,  I don't really see the added value
of having this option to define a cover layer, but that is another point.
By the way, it seems the issue of under-sampling was solved too? At
least, in the limited trials I did, when generating random points I am
actually getting the requested number of sample points, which I didn't
previously! Super!!
Cheers,
Paulo
On 02/07/2013 09:39 AM, Markus Metz wrote:
> On Thu, Feb 7, 2013 at 8:34 AM, Paulo van Breugel
> <p.vanbreugel at gmail.com> wrote:
>> Thanks pointing it out. I have actually used the script some time ago. I
>> think I found that it becomes a bit slow when working with large number of
>> points, but I am going to try in grass 7, see if it is any faster due to
>> faster vector handling.
> In theory, r.random should work for irregular areas if you set a MASK.
> Markus M
>> Cheers,
>> Paulo
>>>   Reporter:  pvanbosgeo  |       Owner:  grass-dev@…
>>>       Type:  defect      |      Status:  new
>>>   Priority:  major       |   Milestone:  7.0.0
>>> Component:  Raster      |     Version:  svn-trunk
>>>   Keywords:  r.random    |    Platform:  Linux
>>>        Cpu:  x86-64      |
>>> Comment(by hamish):
>>>   > It's internal
>>>   (a friend was terrible with apostrophes and to/too/two & after too many
>>>   emails it begins to look natural and the bad habit has rubbed off on me!
>>>   argh!)
>>> Ticket URL: <https://trac.osgeo.org/grass/ticket/1874#comment:6>
>>> GRASS GIS <http://grass.osgeo.org>
>> grass-dev mailing list
>> grass-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20130207/15206600/attachment.html>
