[GRASS-dev] [GRASS GIS] #1878: Metric distance option for v.distance in latlon regions
GRASS GIS trac at osgeo.org
Sat Feb 9 13:27:44 PST 2013
 Reporter:  cmbarton              |       Owner:  grass-dev@…
     Type:  enhancement           |      Status:  new
 Priority:  normal                |   Milestone:  7.0.0
Component:  Vector                |     Version:  svn-trunk
 Keywords:  v.distance, geodesic  |    Platform:  All
      Cpu:  All                   |
Changes (by hamish):
  * keywords:  v.distance => v.distance, geodesic
  * platform:  Unspecified => All
  * cpu:  Unspecified => All
Comment:
 ah, calculating the great circle distance between every node of a polyline
 could be rather computationally expensive, but it is possible if you don't
 mind the wait.
 to clarify: does the current version report decimal degrees (aka garbage)
 for v.distance in a lat/lon location? If so it at least deserves a
 warning, and in general a fatal error is better than plausible but
 actually meaningless results.
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1878#comment:8>
