[GRASS-dev] g.extension not working on debian - grass 6.4.3svn
Margherita Di Leo dileomargherita at gmail.com
Sat Feb 9 14:23:48 PST 2013
Actually, something happened, and it fails again, still on g.html2man..
On Mon, Jan 28, 2013 at 9:43 PM, Margherita Di Leo <
dileomargherita at gmail.com> wrote:
> Hamish,
> KUDOS! It works like a charm, tested with addons in C, in python and in
> bash.
> Thanks A LOT!
> madi
> On Mon, Jan 28, 2013 at 1:16 PM, Hamish <hamish_b at yahoo.com> wrote:
>> Hi,
>> It should be fixed now, please svn up & test a bunch.
>> Tested with d.barb and v.surf.icw, both from run the build
>> dir and after 'make install'. all seemed to be ok.
>> I also backported the update to g.manual so that it will work
>> with man and html help pages for your addon modules too.
>> GRASS> g.manual -m r.stack
>> "man g.addonmodule" still doesn't work; $MANPATH overrides
>> instead of adding to the path, and we'd have to move
>> $ADDONS/docs/man/ to $ADDONS/man/ to get it picked up
>> automatically. (one level above an entry in $PATH, or a sibling
>> directory of something ending in bin/. see /etc/manpath.config)
>> You can get around that with a symlink if you don't mind the
>> clutter.
>> Hamish
> Margherita DI LEO
> Postdoctoral Researcher
> European Commission - DG JRC
> Institute for Environment and Sustainability (IES). Unit H03 – FRC
> Via Fermi, 2749
> I-21027 Ispra (VA) - Italy - TP 261
> Tel. +39 0332 78 3600
> margherita.di-leo at jrc.ec.europa.eu
> Disclaimer: The views expressed are purely those of the writer and may not
> in any circumstance be regarded as stating an official position of the
> European Commission.
Margherita DI LEO
Via Fermi, 2749
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20130209/bb882869/attachment.html>
