[GRASS-dev] [GRASS GIS] #1884: grass7 - cairodriver fails to detect right architecture - OSX 10.8
GRASS GIS trac at osgeo.org
Mon Feb 11 15:54:24 PST 2013
 Reporter:  epifanio   |       Owner:  grass-dev@…
     Type:  defect     |      Status:  new
 Priority:  major      |   Milestone:  7.0.0
Component:  Compiling  |     Version:  svn-trunk
 Keywords:  cairo      |    Platform:  MacOSX
      Cpu:  OSX/Intel  |
 Trying to build grass7 with cairo enabled, the build fails with the
 following error :
 epi:grass_trunk epi$ cd /usr/local/src/grass_trunk/lib/cairodriver
 epi:cairodriver epi$ make
 cc -dynamiclib -compatibility_version 7.0 -current_version 7.0
 -install_name
 /usr/local/grass-7.0.svn/lib/libgrass_cairodriver.7.0.svn.dylib -o
 /usr/local/src/grass_trunk/dist.x86_64-apple-
 darwin12.2.0/lib/libgrass_cairodriver.7.0.svn.dylib
 -L/usr/local/src/grass_trunk/dist.x86_64-apple-darwin12.2.0/lib
 OBJ.x86_64-apple-darwin12.2.0/Box.o OBJ.x86_64-apple-darwin12.2.0/Color.o
 OBJ.x86_64-apple-darwin12.2.0/Draw.o OBJ.x86_64-apple-
 darwin12.2.0/Draw_bitmap.o OBJ.x86_64-apple-darwin12.2.0/Driver.o
 OBJ.x86_64-apple-darwin12.2.0/Erase.o OBJ.x86_64-apple-
 darwin12.2.0/Graph.o OBJ.x86_64-apple-darwin12.2.0/Line_width.o OBJ.x86_64
 -apple-darwin12.2.0/Raster.o OBJ.x86_64-apple-darwin12.2.0/Set_window.o
 OBJ.x86_64-apple-darwin12.2.0/Text.o OBJ.x86_64-apple-darwin12.2.0/read.o
 OBJ.x86_64-apple-darwin12.2.0/read_bmp.o OBJ.x86_64-apple-
 darwin12.2.0/read_ppm.o OBJ.x86_64-apple-darwin12.2.0/read_xid.o
 OBJ.x86_64-apple-darwin12.2.0/write.o OBJ.x86_64-apple-
 darwin12.2.0/write_bmp.o OBJ.x86_64-apple-darwin12.2.0/write_ppm.o
 OBJ.x86_64-apple-darwin12.2.0/write_xid.o  -lgrass_driver.7.0.svn
 -lgrass_gis.7.0.svn -L/usr/local/Cellar/cairo/1.12.12/lib -lcairo
 -liconv
 Undefined symbols for architecture x86_64:
   "_FcConfigGetCurrent", referenced from:
       _Cairo_set_font in Text.o
   "_FcConfigSubstitute", referenced from:
   "_FcDefaultSubstitute", referenced from:
   "_FcFontList", referenced from:
       _font_list_fc in Text.o
   "_FcFontMatch", referenced from:
   "_FcFontSetDestroy", referenced from:
   "_FcInit", referenced from:
   "_FcNameParse", referenced from:
   "_FcObjectSetBuild", referenced from:
   "_FcObjectSetDestroy", referenced from:
   "_FcPatternCreate", referenced from:
   "_FcPatternDestroy", referenced from:
   "_FcPatternGetString", referenced from:
 ld: symbol(s) not found for architecture x86_64
 clang: error: linker command failed with exit code 1 (use -v to see
 invocation)
 make: *** [/usr/local/src/grass_trunk/dist.x86_64-apple-
 darwin12.2.0/lib/libgrass_cairodriver.7.0.svn.dylib] Error 1
 this is not correct, the cairo lib installed on my machine are built as
 universal in both arch 32 and 64 bit.
 lipo -info /usr/local/Cellar/cairo/1.12.12/lib/cairo/libcairo-
 trace.0.dylib /usr/local/Cellar/cairo/1.12.12/lib/libcairo-gobject.2.dylib
 /usr/local/Cellar/cairo/1.12.12/lib/libcairo-script-interpreter.2.dylib
 /usr/local/Cellar/cairo/1.12.12/lib/libcairo.2.dylib
 Architectures in the fat file: /usr/local/Cellar/cairo/1.12.12/lib/cairo
 /libcairo-trace.0.dylib are: i386 x86_64
 /libcairo-gobject.2.dylib are: i386 x86_64
 /libcairo-script-interpreter.2.dylib are: i386 x86_64
 /usr/local/Cellar/cairo/1.12.12/lib/libcairo.2.dylib are: i386 x86_64
 epi:~ epi$
 /usr/local/Cellar/fontconfig/2.10.91/bin/fc-cache:    Mach-O universal
 binary with 2 architectures
 /usr/local/Cellar/fontconfig/2.10.91/bin/fc-cache (for architecture i386):
 Mach-O executable i386
 x86_64):    Mach-O 64-bit executable x86_64
 /usr/local/Cellar/fontconfig/2.10.91/bin/fc-cat:      Mach-O universal
 /usr/local/Cellar/fontconfig/2.10.91/bin/fc-cat (for architecture i386):
 /usr/local/Cellar/fontconfig/2.10.91/bin/fc-cat (for architecture x86_64):
 /usr/local/Cellar/fontconfig/2.10.91/bin/fc-list:     Mach-O universal
 /usr/local/Cellar/fontconfig/2.10.91/bin/fc-list (for architecture i386):
 /usr/local/Cellar/fontconfig/2.10.91/bin/fc-match:    Mach-O universal
 /usr/local/Cellar/fontconfig/2.10.91/bin/fc-match (for architecture i386):
 /usr/local/Cellar/fontconfig/2.10.91/bin/fc-pattern:  Mach-O universal
 /usr/local/Cellar/fontconfig/2.10.91/bin/fc-pattern (for architecture
 i386):    Mach-O executable i386
 /usr/local/Cellar/fontconfig/2.10.91/bin/fc-query:    Mach-O universal
 /usr/local/Cellar/fontconfig/2.10.91/bin/fc-query (for architecture i386):
 /usr/local/Cellar/fontconfig/2.10.91/bin/fc-scan:     Mach-O universal
 /usr/local/Cellar/fontconfig/2.10.91/bin/fc-scan (for architecture i386):
 /usr/local/Cellar/fontconfig/2.10.91/bin/fc-validate: Mach-O universal
 /usr/local/Cellar/fontconfig/2.10.91/bin/fc-validate (for architecture
 x86_64):Mach-O 64-bit executable x86_64
 suspect :
 seems that the GRASS Configure is not storing the fontconfig linking in
 platform.make so it doesn't get into the cairo driver compilation.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1884>
