[GRASS-dev] error in compiling latest i.landsat.toar
SWAPAN GHOSH
swap.ghsh at gmail.com
Tue Feb 12 02:52:41 PST 2013
can you please give me you source code as* landsat_met.c *or you can check
your code in line 82,83 and 192,193.
*Regards,*
*swapan
On Tue, Feb 12, 2013 at 4:17 PM, Nikos Alexandris
<nik at nikosalexandris.net>wrote:
> nik at eScientific:/geo/osgeo/src/grass_trunk/imagery/i.landsat.toar$ make
> gcc -g -O2 -I/geo/osgeo/src/grass_trunk/dist.x86_64-unknown-linux-
> gnu/include
> -I/geo/osgeo/src/grass_trunk/dist.x86_64-unknown-linux-gnu/include
> -D_FILE_OFFSET_BITS=64 -DPACKAGE=\""grassmods"\" -
> I/geo/osgeo/src/grass_trunk/dist.x86_64-unknown-linux-gnu/include -
> I/geo/osgeo/src/grass_trunk/dist.x86_64-unknown-linux-gnu/include -o
> OBJ.x86_64-unknown-linux-gnu/landsat_met.o -c landsat_met.c
> landsat_met.c: In function ‘lsat_metadata’:
> landsat_met.c:83:7: error: expected expression before ‘/’ token
> landsat_met.c:193:14: error: expected expression before ‘/’ token
> make: *** [OBJ.x86_64-unknown-linux-gnu/landsat_met.o] Error 1
> Thanks, Nikos
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20130212/366e66c9/attachment.html>
