[GRASS-dev] does GRASS 7 for Mac compile yet?
Anna Kratochvílová kratochanna at gmail.com
Tue Feb 12 04:48:28 PST 2013
Hi Massimo,
I have hopefully fixed some of the errors you sent me. Could you go
through them again and make an updated list of errors? I will try to
fix as much as possible and for the rest you should create a ticket
not to forget about them.
The problem with wxversion is strange, I have now similar problem too
(with Ubuntu 12.04).
On Tue, Feb 12, 2013 at 12:56 AM, epi <massimodisasha at gmail.com> wrote:
> Thank you Anna,
> i'll be happy to try any solution.
> in the main time i opened a bug :
> http://trac.osgeo.org/grass/ticket/1884
> related to the cairodriver, is mac specific but not directly related to the gui
perhaps someone else could help you with this?
Anna
> Massimo.
> Il giorno 08/feb/2013, alle ore 06:28, Anna Kratochvílová <kratochanna at gmail.com> ha scritto:
> > Hi,
> > I am able to fix certain problems but sometimes the error messages are
> > not helpful much and I need to test myself but I don't have the Mac
> > with the wxpython 2.9. During the community sprint I tested it a
> > little on Nikos' computer but I didn't have enough time.
> > On Thu, Feb 7, 2013 at 11:28 PM, massimo di stefano
> >> Is this way to debug the gui useful for you dev ?
> >> is there anything i can try to do for you to help in debugging ?
> > I can send you a patch to test but it can take a long time to fix it
> > because I don't usually have clear idea what can be wrong. However,
> > this is probably the only way, now. I will try to work on it in the
> > next days/weeks.
> > Thanks for the testing,
> > Anna
> >> I think the cairo problem is related to grass core, not just the gui.
> >> anyone can help in fixing the build error ?
> >> thanks!
> >> Massimo.
> >> Hi Anna,
> >> it fails to import the wxversion module.
> >> ERROR: wxGUI requires wxPython. No module named wxversion
> >> Error in GUI startup. If necessary, please report this error to the GRASS
> >> developers.
> >> Switching to text mode now.
> >> Hit RETURN to continue...
> >> i had to comment the lines :
> >> #if not os.getenv("GRASS_WXBUNDLED"):
> >> #    CheckForWx()
> >> thanks for the fix, the rasrer map is displayed correctly without any
> >> changes to the code.
> >> testing the gui ..
> >> - pointer, query, pan, zoom (all the options)  [works]
> >> - measure tool [works]
> >> - profile tool doesn't work [doesn't work]
> >> it let me select the raster map, then shows a blanc "Grass Profile Analysis"
> >> in the status bar i can see "left mouse down at point (float, float)"
> >> when click on the map i got in the "command console" :
> >> (Wed Feb  6 11:12:13 2013)
> >> r.what --v -f -n map=elevation.10m at PERMANENT
> >> coordinates=595356.617647,4923676.470588
> >> easting|northing|site_name|elevation.10m at PERMANENT|elevation.10m at PERMANENT_label
> >> 595356.617647|4923676.470588||1253.797607|
> >> (Wed Feb  6 11:12:13 2013) Command finished (0 sec)
> >> (Wed Feb  6 11:12:26 2013)
> >> coordinates=599551.470588,4920665.441176
> >> 599551.470588|4920665.441176||1344.138306|
> >> (Wed Feb  6 11:12:26 2013) Command finished (0 sec)
> >> (Wed Feb  6 11:12:30 2013)
> >> coordinates=596669.117647,4921051.470588
> >> 596669.117647|4921051.470588||1400.473877|
> >> .. but nothing is displayed back to the profile tool
> >> - Grass histogramming Tool [doesn't work] :
> >> it show me the "Grass histogramming Tool " window, but then i got this log
> >> in the console :
> >> (Wed Feb  6 11:12:37 2013) Command finished (0 sec)
> >> Traceback (most recent call last):
> >>  File "/usr/local/grass-7.0.svn/etc/gui/wxpython/mapdisp/fr
> >> ame.py", line 1101, in OnHistogramPyPlot
> >> win.OnSelectRaster(None)
> >>  File "/usr/local/grass-7.0.svn/etc/gui/wxpython/wxplot/his
> >> togram.py", line 96, in OnSelectRaster
> >> self.OnCreateHist(event = None)
> >> togram.py", line 76, in OnCreateHist
> >> self.SetGraphStyle()
> >>  File
> >> "/usr/local/grass-7.0.svn/etc/gui/wxpython/wxplot/base.py",
> >> line 353, in SetGraphStyle
> >> self.client.SetGridColour(wx.Color(self.properties['grid']['
> >> color'][0],
> >> AttributeError
> >> 'module' object has no attribute 'Color'
> >> - Create histogram with d.histogram [works*] :
> >> *the image is displayed correctly in the "GRASS GIS Histogramming Tool
> >> (d.histogram)"
> >> no option to save it, i got this log in the console :
> >>  File "/usr/local/grass-7.0.svn/etc/gui/wxpython/modules/hi
> >> stogram.py", line 124, in OnPaint
> >> dc = wx.BufferedPaintDC(self, self._buffer)
> >>  File "/usr/local/lib/python2.7/site-packages/wx/_gdi.py",
> >> line 5286, in __init__
> >> _gdi_.BufferedPaintDC_swiginit(self,_gdi_.new_BufferedPaintD
> >> C(*args, **kwargs))
> >> TypeError
> >> in method 'new_BufferedPaintDC', expected argument 2 of type
> >> 'wxBitmap &'
> >> - Add scale bar and north arrow [works]
> >> - Add legend [works
> >> - Add text layer [doesn't work] :
> >> ame.py", line 1209, in OnAddText
> >> self.SwitchTool(self.toolbars['map'], event)
> >> ame.py", line 1378, in SwitchTool
> >> self.UpdateTools(event)
> >> ame.py", line 1400, in UpdateTools
> >> if event.GetEventObject().GetId() == \
> >> AttributeError
> >> 'Menu' object has no attribute 'GetId'
> >> - Save display to graphic file [works]
> >> - Print [works]
> >> - switch to 3D (wxNviz) [doesn't work]:
> >> Starting 3D view mode...
> >>  File "/usr/local/grass-7.0.svn/etc/gui/wxpython/mapdisp/to
> >> olbars.py", line 229, in OnSelectTool
> >> self.parent.AddNviz()
> >> ame.py", line 328, in AddNviz
> >> self._layerManager.AddNvizTools()
> >>  File
> >> "/usr/local/grass-7.0.svn/etc/gui/wxpython/lmgr/frame.py",
> >> line 341, in AddNvizTools
> >> display = self.GetMapDisplay())
> >>  File
> >> "/usr/local/grass-7.0.svn/etc/gui/wxpython/nviz/tools.py",
> >> line 102, in __init__
> >> self.AddPage(page = self._createAnimationPage(),
> >>  File
> >> line 401, in _createAnimationPage
> >> usage = "record", label = _("Record"))
> >>  File "/usr/local/grass-7.0.svn/etc/gui/wxpython/gui_core/w
> >> idgets.py", line 405, in __init__
> >> maskColor = wx.Color(255, 255, 255)
> >> AttributeError
> >>  File "/usr/local/grass-7.0.svn/etc/gui/wxpython/mapdisp/ma
> >> pwindow.py", line 463, in OnIdle
> >> self.UpdateMap()
> >> pwindow.py", line 687, in UpdateMap
> >> pdctype = self.overlays[id].pdcType, coords =
> >> self.overlays[id].coords)
> >> KeyError
> >> 0
> >> # afeter that i was not able to have the 2D map back working, opening a new
> >> display fixed it.
> >> - vector tools [doesn't work] :
> >> i guess the main problem is the cairo driver .. in any case this is part of
> >> the log i got :
> >> pwindow.py", line 1000, in MouseActions
> >> self.OnLeftUp(event)
> >> pwindow.py", line 1214, in OnLeftUp
> >> self._onLeftUp(event)
> >>  File "/usr/local/grass-7.0.svn/etc/gui/wxpython/vdigit/map
> >> window.py", line 834, in _onLeftUp
> >> if len(self.digit.GetDisplay().GetSelected()) > 0:
> >> AttributeError
> >> 'NoneType' object has no attribute 'GetDisplay'
> >> (and a pop up no vector map selected for editing)
> >> i had to build without cairo support .. because of the error i posted
> >> before.
> >> thanks to William that point out it can be a configuration problem
> >> GRASS Configure is not storing the fontconfig linking in
> >>> platform.make so it doesn't get into the cairo driver compilation.
> >> also building without-cairo  when try to display vector data the gui
> >> complain about missed cairo.
> >> i tried to change the driver in the gui preference from cairo to png but
> >> then the gui freeze and i have to force-quit it.
> >> i'll be happy to continue testing if can be of any help,
> >> thanks for the hard work!
> >> Massimo
> >> 2013/2/5 Anna Kratochvílová <kratochanna at gmail.com>
> >>> Hi,
> >>> On Mon, Feb 4, 2013 at 11:57 PM, epi <massimodisasha at gmail.com> wrote:
> >>>> i'm trying to debug the build of GRASS 7 on mac OSX 10.8.x in 64 bit
> >>>> with WX
> >>>> 2.9.x
> >>>> After commenting the check for wx version i got the GUI start, some
> >>>> worning
> >>> what exactly is the problem with the 'check for wx version'? The
> >>> warning (wx.InitAllImageHandlers) and the PrepareDC error should be
> >>> fixed now.
> >>> Anna
> >>>> GRASS 7.0.svn (spearfish60):~ >
> >>>> /usr/local/grass-7.0.svn/etc/gui/wxpython/wxgui.py:54:
> >>>> wxPyDeprecationWarning: Call to deprecated item 'InitAllImageHandlers'.
> >>>>  wx.InitAllImageHandlers()
> >>>> /usr/local/grass-7.0.svn/etc/gui/wxpython/gui_core/goutput.py:230:
> >>>> wxPyDeprecationWarning: Call to deprecated item 'SetVirtualSizeHints'.
> >>>>  outputSizer.SetVirtualSizeHints(self.panelOutput)
> >>>> the Window Manager seems to work properly (i cal load a layer Rast/Vect
> >>>> in
> >>>> the lkayer tree, the shell also pront out the log of commands nicely)
> >>>> but i can't display layers (both Vector and Raster are not displayed).
> >>>> Commenting  this 2 line in madisp.py :
> >>>> 359         #self.PrepareDC(dc)
> >>>> 519        #self.PrepareDC(dc)
> >>>> i got the Raster map displaying properly
> >>>> but no vector, the error is in a missed Cairo Driver :
> >>>> /usr/local/grass-7.0.svn/etc/gui/wxpython/gui_core/ghelp.py:
> >>>> 608: wxPyDeprecationWarning: Call to deprecated item
> >>>> Command 'd.vect map=archsites at PERMANENT
> >>>> type=point,line,area,face' failed
> >>>> Details: Unknown display driver <cairo>
> >>>> I wasn't able to get the cairo driver working during the Make step, it
> >>>> shows
> >>>> the error at the end of the log [1]
> >>>> about a missed arch ... but i guess ... I have everything built as
> >>>> --universal
> >>>> In doubt I rebuilt fontconfig and cairo and checked the relative
> >>>> architecture :
> >>>> lipo -info
> >>>> /usr/local/Cellar/cairo/1.12.12/lib/cairo/libcairo-trace.0.dylib
> >>>> /usr/local/Cellar/cairo/1.12.12/lib/libcairo-gobject.2.dylib
> >>>> /usr/local/Cellar/cairo/1.12.12/lib/libcairo-script-interpreter.2.dylib
> >>>> /usr/local/Cellar/cairo/1.12.12/lib/libcairo.2.dylib
> >>>> Architectures in the fat file:
> >>>> /usr/local/Cellar/cairo/1.12.12/lib/cairo/libcairo-trace.0.dylib are:
> >>>> i386
> >>>> x86_64
> >>>> /usr/local/Cellar/cairo/1.12.12/lib/libcairo-gobject.2.dylib are: i386
> >>>> x86_64
> >>>> are:
> >>>> i386 x86_64
> >>>> /usr/local/Cellar/cairo/1.12.12/lib/libcairo.2.dylib are: i386 x86_64
> >>>> epi:~ epi$
> >>>> /usr/local/Cellar/fontconfig/2.10.91/bin/fc-cache:    Mach-O universal
> >>>> binary with 2 architectures
> >>>> /usr/local/Cellar/fontconfig/2.10.91/bin/fc-cache (for architecture
> >>>> i386):
> >>>> Mach-O executable i386
> >>>> x86_64):
> >>>> Mach-O 64-bit executable x86_64
> >>>> /usr/local/Cellar/fontconfig/2.10.91/bin/fc-cat:      Mach-O universal
> >>>> /usr/local/Cellar/fontconfig/2.10.91/bin/fc-cat (for architecture i386):
> >>>> x86_64):
> >>>> /usr/local/Cellar/fontconfig/2.10.91/bin/fc-list:     Mach-O universal
> >>>> /usr/local/Cellar/fontconfig/2.10.91/bin/fc-list (for architecture
> >>>> i386):
> >>>> x86_64):
> >>>> /usr/local/Cellar/fontconfig/2.10.91/bin/fc-match:    Mach-O universal
> >>>> /usr/local/Cellar/fontconfig/2.10.91/bin/fc-match (for architecture
> >>>> i386):
> >>>> x86_64):
> >>>> /usr/local/Cellar/fontconfig/2.10.91/bin/fc-pattern:  Mach-O universal
> >>>> /usr/local/Cellar/fontconfig/2.10.91/bin/fc-pattern (for architecture
> >>>> i386):
> >>>> x86_64): Mach-O 64-bit executable x86_64
> >>>> /usr/local/Cellar/fontconfig/2.10.91/bin/fc-query:    Mach-O universal
> >>>> /usr/local/Cellar/fontconfig/2.10.91/bin/fc-query (for architecture
> >>>> i386):
> >>>> x86_64):
> >>>> /usr/local/Cellar/fontconfig/2.10.91/bin/fc-scan:     Mach-O universal
> >>>> /usr/local/Cellar/fontconfig/2.10.91/bin/fc-scan (for architecture
> >>>> i386):
> >>>> x86_64):
> >>>> /usr/local/Cellar/fontconfig/2.10.91/bin/fc-validate: Mach-O universal
> >>>> /usr/local/Cellar/fontconfig/2.10.91/bin/fc-validate (for architecture
> >>>> i386): Mach-O executable i386
> >>>> x86_64):Mach-O 64-bit executable x86_64
> >>>> They are multi-arch, but unlucky i still have the same error in
> >>>> cairodriver,
> >>>> [1] http://epi.whoi.edu/esr/grass7_cairodriver_log.txt   <-- full build
> >>>> log
> >>>> William K. helped me to debug the error,
> >>>> and seems that the GRASS Configure is not storing the fontconfig linking
> >>>> in
> >>>> thanks for helping me,
> >>>> Massimo.
> >>>> Il giorno 31/gen/2013, alle ore 13:04, Michael Barton
> >>>> <michael.barton at asu.edu> ha scritto:
> >>>> It may work with wxPython 2.9 but nobody has been able to test yet.
> >>>> Michael
> >>>> ______________________________
> >>>> C. Michael Barton
> >>>> Director, Center for Social Dynamics & Complexity
> >>>> Professor of Anthropology, School of Human Evolution & Social Change
> >>>> Arizona State University
> >>>> Tempe, AZ  85287-2402
> >>>> USA
> >>>> voice:  480-965-6262 (SHESC), 480-727-9746 (CSDC)
> >>>> fax:          480-965-7671(SHESC), 480-727-0709 (CSDC)
> >>>> www:  http://csdc.asu.edu, http://shesc.asu.edu
> >>>> http://www.public.asu.edu/~cmbarton
> >>>> On Jan 31, 2013, at 3:47 AM, epi <massimodisasha at gmail.com>
> >>>> wrote:
> >>>> I'm a mac user as well and i will be happy to help,
> >>>> … i built grass weekly (if not daily) in the past,
> >>>> but unfortunately now i'm on mac 10.8.x using 64bit python, all my
> >>>> python
> >>>> packages numpy scipy etc etc etc .. are 64 bit and ...
> >>>> WX gui
> >>>> <start-joke>
> >>>>    great choice
> >>>> </end-joke>
> >>>> unfortunately doesn't works on mac in 64 bit mode … i'm waiting the
> >>>> 2.9.x to
> >>>> be stable that is 2 years now ...
> >>>> This IMO can be one of the major reason of  "lack of mac-man-dev-power"
> >>>> i can provide log on the build of grass7 (without gui modules) … but
> >>>> this
> >>>> doesn't help
> >>>> i don't know if grass-gui-dev want try to test grass with wx-2.9 .. it
> >>>> is
> >>>> unstable but works, if yes .. i'll be happy to be a guinea pig
> >>>> --Massimo
> >>>> Il giorno 31/gen/2013, alle ore 05:32, Thomas Adams - NOAA Federal
> >>>> <thomas.adams at noaa.gov> ha scritto:
> >>>> All,
> >>>> I'm a Mac user in addition to Linux. I'm going to have more free time
> >>>> starting in a few weeks. I'd be happy to step-up my use of GRASS 7 for
> >>>> testing. Just let me know what I can do. I'm moving from the U.S. to
> >>>> Melbourne, Australia in a couple of weeks!
> >>>> Cheers,
> >>>> Tom
> >>>> On Thu, Jan 31, 2013 at 5:27 AM, Luca Delucchi <lucadeluge at gmail.com>
> >>>> wrote:
> >>>>> 2013/1/31 Margherita Di Leo <dileomargherita at gmail.com>:
> >>>>>> I think we should consider to promote a fund rising for buying a
> >>>>>> (used,
> >>>>>> discounted, whatever) mac computer for the use of developers who are
> >>>>>> developing or are willing to test on it. What do you think?
> >>>>> I don't like this idea.
> >>>>> I think should be really better to have some more Mac power user
> >>>>> instead, and use the money for community sprint
> >>>>>> my 2 c
> >>>>>> madi
> >>>>> ciao
> >>>>> Luca
> >>>>> http://gis.cri.fmach.it/delucchi/
> >>>>> www.lucadelu.org
> >>>>> _______________________________________________
> >>>>> grass-dev mailing list
> >>>>> grass-dev at lists.osgeo.org
> >>>>> http://lists.osgeo.org/mailman/listinfo/grass-dev
> >>>> Thomas E Adams
> >>>> Development & Operations Hydrologist
> >>>> National Weather Service
> >>>> Ohio River Forecast Center
> >>>> 1901 South State Route 134
> >>>> Wilmington, OH 45177
> >>>> http://www.erh.noaa.gov/er/ohrfc/
> >>>> EMAIL:        thomas.adams at noaa.gov
> >>>> VOICE:        937-383-0528
> >>>> FAX:  937-383-0033
