[GRASS-dev] [GRASS GIS] #1882: new query display needs to update on mouse click
trac at osgeo.org
Tue Feb 12 15:15:07 PST 2013
Reporter: cmbarton | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: wxGUI | Version: svn-trunk
Keywords: query | Platform: Unspecified
Cpu: Unspecified |
Comment(by annakrat):
Replying to [comment:11 cmbarton]:
> The coordinates show up fine but no update. If you can point me to the
relevant mouse binding code, I could see if I can fix it.
That would be great because I don't know what could be the problem. The
code doing the query is in mapdisp/frame.py in QueryMap method which is
called from Query method. This is called from mapdisp/mapwindow.py, line
1187. So I would put some prints and see where it is blocked.
Thanks,
Anna
Ticket URL: <http://trac.osgeo.org/grass/ticket/1882#comment:12>
