[GRASS-dev] [GRASS GIS] #1884: grass7 - cairodriver fails to detect right architecture - OSX 10.8
GRASS GIS trac at osgeo.org
Wed Feb 13 21:23:16 PST 2013
 Reporter:  epifanio   |       Owner:  grass-dev@…
     Type:  defect     |      Status:  new
 Priority:  major      |   Milestone:  7.0.0
Component:  Compiling  |     Version:  svn-trunk
 Keywords:  cairo      |    Platform:  MacOSX
      Cpu:  OSX/Intel  |
Comment(by glynn):
 Replying to [ticket:1884 epifanio]:
 > seems that the GRASS Configure is not storing the fontconfig linking in
 platform.make so it doesn't get into the cairo driver compilation.
 configure sets CAIROLIB to whatever it gets from
 pkg-config --libs cairo-ft cairo-fc cairo-pdf cairo-ps cairo-svg
 plus anything added manually via the --with-cairo-libs and/or --with-
 cairo-ldflags switches.
 However: lib/cairodriver uses fontconfig directly, as well as via cairo.
 The above list of undefined symbols is exactly the set of fontconfig
 functions which lib/cairodriver/Text.c references directly.
 So we probably need to add "fontconfig" to the pkg-config command. Try
 r55040.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1884#comment:2>
