[GRASS-dev] [GRASS GIS] #1866: broken db driver communication in winGRASS 7 (was: broken SQLite driver in winGRASS 7)
trac at osgeo.org
Thu Feb 14 00:33:42 PST 2013
Reporter: martinl | Owner: grass-dev@…
Type: defect | Status: new
Priority: blocker | Milestone: 7.0.0
Component: Database | Version: unspecified
Keywords: sqlite, wingrass | Platform: MSWindows 2K
Cpu: Unspecified |
Comment(by mmetz):
Replying to [comment:11 cmbarton]:
> This seems to be working fine on the Mac for R55039. I just did
db.describe for forestations in the nc_spm_08 demo set for data in sqlite.
No problem.
The drivers are working just fine. Someone is not listening properly, i.e.
the dblib as used by modules, because the drivers are sending correct
information, but the dblib receives bargage. There are some parts in the
code, in the db lib, in gislib for spawning and in the wxGUI that have
switches for Windows. But the relevant code in the db drivers, the db lib
and gislib is identical between 6.4, 6.5 and 7. The only differences I
could find between trunk and devbr6/relbr64 are in the GRASS startup
script and in the wxGUI. Is it possible that the wxGUI or the startup
script are highjacking file descriptors of the pipes?
Markus M
Ticket URL: <https://trac.osgeo.org/grass/ticket/1866#comment:12>
