[GRASS-dev] [GRASS-user] i.landsat.toar fails to convert DNs (bands 61 and 62) to temperature for Landsat 7 scene
Nikos Alexandris
nik at nikosalexandris.net
Thu Feb 14 05:33:17 PST 2013
Nikos Alexandris wrote:
> While i.landsat.toar works just fine with all bands in converting DNs to
> Radiance/Reflectance (with some method=dos?), it seems, at least in once
> case (scene LE71840312002041SGS00), it fails to convert bands 61 and 62 in
> temperature!
> Same happens (as described below in both G64 and G70).
> Can anyone confirm or reject?
[deleted stuff]
Using the old metadata file (in this case: LE71840312002041SGS00_MTLold.txt)
works fine.
GRASS 6.4.3svn (wgs84_utm_z34_test):~ > r.info -r B.DOS1.ToCR.61
min=158.263805493393
max=338.623091571347
GRASS 6.4.3svn (wgs84_utm_z34_test):~ > r.info -r B.DOS1.ToCR.62
min=240.06999848884
max=322.080084447704
I guess it is a bug (something that got away in latest updates of
i.landsat.toar towards the newer metadata file). Will try to check further...
not today though, deadlines approaching.
Best, Nikos
