[GRASS-dev] [GRASS GIS] #1886: Error in input may result in r.proj overwriting exising layers
GRASS GIS trac at osgeo.org
Fri Feb 15 05:15:20 PST 2013
 Reporter:  pvanbosgeo  |       Owner:  grass-dev@…
     Type:  defect      |      Status:  new
 Priority:  normal      |   Milestone:  7.0.0
Component:  Raster      |     Version:  svn-trunk
 Keywords:              |    Platform:  Unspecified
      Cpu:  x86-64      |
Comment(by glynn):
 Replying to [ticket:1886 pvanbosgeo]:
 > A more consistent behavior, i.m.h.o., would be if in both steps, the
 '@mapset' is ignored (which would eliminate the possibility of unwittingly
 overwriting layers). Alternatively, it should be impossible to use an
 input name which includes a '@mapset' part (doing so should give an error
 message).
 The most consistent behaviour would be to make the output= parameter non-
 optional. The parser will automatically generate an error if an "output"
 map exists and overwrite wasn't enabled.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1886#comment:1>
