[GRASS-dev] Additional switch(es) for <g.mapsets>?
Martin Landa
landa.martin at gmail.com
Sat Feb 16 05:54:48 PST 2013
2013/2/16 Nikos Alexandris <nik at nikosalexandris.net>:
> A use case is, for example, that I need to selectively use i.landsat.toar on
> many Mapsets (that is, on many Landsat scenes) with the default
> method(=uncorrected) and produce At-Sensor-Reflectances while performing
> conversion to Top-of-Atmosphere Radiance with i.landsat.toar's "-r" switch.
> Currently, in bash-scripting G7, I try first to remove access to all mapsets
> but the current (of course) as follows:
> # one-liner!
> g.mapsets mapset=$(g.mapsets -p sep=newline | grep -v `g.mapset -p` | tr "\n"
> ",") operation=remove
If I understood well, you want something like
g.mapsets set=<current_mapset>
Martin
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
