[GRASS-dev] [GRASS GIS] #1606: WXGUI regression - attribute query tool reports "nothing found" when clicking on a vector object
GRASS GIS trac at osgeo.org
Sun Feb 17 08:54:35 PST 2013
  Reporter:  marisn       |       Owner:  grass-dev@…
      Type:  defect       |      Status:  reopened
  Priority:  blocker      |   Milestone:  6.4.3
 Component:  wxGUI        |     Version:  6.4.3 RCs
Resolution:               |    Keywords:  query
  Platform:  Unspecified  |         Cpu:  Unspecified
Changes (by annakrat):
  * keywords:  => query
Comment:
 Sorry if I misunderstood the problem but I have just tested it (Linux,
 Windows) and I get right results. I created new vector in digitizer
 without db connection and created two areas, one (centroid) with layer 1
 and cat 1 and second in layer 2 with cat 1. Querying outputs expected
 results.
 Module v.what used for queries does not know anything about d.vect options
 layer and cats. Maybe there should be some connection but this is a
 different problem.
 Anna
Ticket URL: <http://trac.osgeo.org/grass/ticket/1606#comment:6>
