#1758: Disabling python support does not prevent entry into python directories
during build
Reporter: brook | Owner: grass-dev@…
Type: defect | Status: reopened
Priority: major | Milestone: 6.4.3
Component: Compiling | Version: 6.4.2
Resolution: | Keywords: python, wxgui
Platform: All | Cpu: Unspecified
Changes (by hamish):
* keywords: => python, wxgui
* priority: critical => major
* component: Python => Compiling
Comment:
[trac is logging me out every 5 minutes.. arrgh]
I just tried rebuilding on the old machine --with-python and --without-
wxwidgets in comment:5, it was ok.
Building with 'make -j 5' I did get an error logged in the gui/wxpython/
dir, but cd'ing to it and running make again was successful, so I suspect
that some Makefile order-of-build dependency issue still exists, but
overall it's happy.
Is the goal to build on a system without any python on it, to build on a
system without wxWidgets on it, or to just not build the wxGUI?
If it's just to avoid building with the wxGUI it's not really a problem,
since most of it is not really built, just copied in place and then left
unused.
> As a result, this option results in a failed build.
what was the error?
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1758#comment:6>
