[GRASS-dev] [GRASS GIS] #1758: Disabling python support does not prevent entry into python directories during build
trac at osgeo.org
Mon Feb 18 01:24:05 PST 2013
during build
Reporter: brook | Owner: grass-dev@…
Type: defect | Status: reopened
Priority: major | Milestone: 6.4.3
Component: Compiling | Version: 6.4.2
Resolution: | Keywords: python, wxgui
Platform: All | Cpu: Unspecified
Comment(by hamish):
I just tried 6.4.3svn again --without-python and --without-wxwidgets.
The experience was the same. It still tried to `make` the wxwidgets gui,
and failed with this error:
python -m py_compile /usr/local/src/grass/svn/releasebranch_6_4/dist.i686
-pc-linux-gnu/etc/wxpython/wxplot/profile.py
-pc-linux-gnu/etc/wxpython/gis_set.py
-pc-linux-gnu/etc/wxpython/wxgui.py
GISRC=/usr/local/src/grass/svn/releasebranch_6_4/dist.i686-pc-linux-
gnu/demolocation/.grassrc64
GISBASE=/usr/local/src/grass/svn/releasebranch_6_4/dist.i68
6-pc-linux-gnu PATH="/usr/local/src/grass/svn/releasebranch_6_4/dist.i686
-pc-linux-gnu/bin:$PATH"
PYTHONPATH="/usr/local/src/grass/svn/releasebranch_6_4/di
st.i686-pc-linux-gnu/etc/python:$PYTHONPATH"
LD_LIBRARY_PATH="/usr/local/src/grass/svn/releasebranch_6_4/dist.i686-pc-
linux-gnu/bin:/usr/local/src/grass/sv
n/releasebranch_6_4/dist.i686-pc-linux-gnu/lib::" LC_ALL=C python
core/menudata.py > menustrings.py
File "core/menudata.py", line 39, in ?
import wx
ImportError: No module named wx
make[2]: *** [menustrings.py] Error 1
make[2]: Leaving directory
`/usr/local/src/grass/svn/releasebranch_6_4/gui/wxpython'
make[1]: Leaving directory
`/usr/local/src/grass/svn/releasebranch_6_4/gui'
make[1]: Entering directory
`/usr/local/src/grass/svn/releasebranch_6_4/imagery'
but after cd'ing into the dir and trying a second time it built ok.
note python was present on the system (see lack of errors about that in
the above log snippet), I'm not sure what would happen if it wasn't
installed, e.g. with the attempted byte compiling of lib/python/ and
population of dist.`arch`/etc/python/grass/lib/.
Probably you'd get a non-fatal error about it listed in error.log.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1758#comment:7>
