[GRASS-dev] [GRASS GIS] #1554: wxGUI Cartographic Composer: preview broken on Windows
trac at osgeo.org
Mon Feb 18 12:52:56 PST 2013
Reporter: martinl | Owner: grass-dev@…
Type: defect | Status: new
Priority: critical | Milestone: 6.4.3
Component: wxGUI | Version: unspecified
Keywords: cartographic composer, psmap, wingrass | Platform: MSWindows XP
Cpu: Unspecified |
Comment(by wenzeslaus):
Replying to [comment:18 hamish]:
> Along the line to make it more obvious: how about if the initial preview
document loaded a dummy graphic which had a picture of the green triangle
button circled and an arrow pointing NW saying "click up there to generate
preview".
Good idea. Generally, we should try to add some hints this and there in
the GUI to guide user what to do, what does this and that mean. Example of
this is a recently added gray text in command console with hint to use
Ctrl+Space and Tab keys.
The text would be enough for me. The graphics seems to be little bit too
much.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1554#comment:19>
